Coilovers or LSD?
Old Oct 7, 2011 | 02:21 AM
acke15's Avatar
acke15
Default Coilovers or LSD?
So I'm about to sell my coils. *And get new coils or get a LSD. *I have about 1100 to spend on either.if I get coils, I want a true coilover. Ive heard mixed reviews on clutch type lsd's. My z isn't a daily. And I like to autox it. And want to track it more.
Old Oct 7, 2011 | 02:44 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
if you have a base model i would go with the lsd otherwise i'd suggest coilovers first
Old Oct 7, 2011 | 03:32 AM
r_seng's Avatar
r_seng
Old Oct 7, 2011 | 03:43 AM
terrasmak's Avatar
The stock suspension is actually pretty good, but the stock VLSD blows, you will get better improvements while autocrossing and at the track with an LSD. If i had to do it again, an LSD would be one of my first mods.
Also $1100 won't get you a set of coilovers that are better than an OEM 04.5 and newer suspension.
Old Oct 7, 2011 | 04:32 AM
acke15's Avatar
acke15
It's the ethusiast model. But would a clutch type be the way to go?
Old Oct 7, 2011 | 04:33 AM
acke15's Avatar
acke15
It's a 2006 as well.
Old Oct 7, 2011 | 11:01 AM
drivessidewayz's Avatar
drivessidewayz
Clutch vs. Helical is up to you. I love my Carbonetic and I dd my Z when I feel like it. I can add that it makes drifting a breeze
Old Oct 7, 2011 | 01:14 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
os giken ftw
Old Oct 7, 2011 | 05:54 PM
SE5spd's Avatar
SE5spd
os giken ftw
x100
Old Oct 7, 2011 | 06:17 PM
Viksz33's Avatar
Viksz33
+1, What he said
Stock suspension is fine especially compared to $1,100 coilovers. And if all you have is $1,100 check out the Nismo LSD. It is very agressive, but it is loud. IMO the Nismo LSD is the best for the money. But if your really want better coilovers, try and save a little more for some KW's. The V3s are my next mod. Im currently running the V1s.
Old Oct 9, 2011 | 07:15 PM
CTZ860's Avatar
CTZ860
U guys chimin in about the carbo and the giken.....how are they for noise? Ive heard that the carbonetics is pretty quiet, would you agree?
Old Oct 9, 2011 | 11:17 PM
SE5spd's Avatar
SE5spd
what I hear is OSG is pretty much as quite as stock?
I cant wait until I order my OS GIKEN
Old Oct 11, 2011 | 01:11 PM
CTZ860's Avatar
CTZ860
Is the giken 1.5 way or 2 way? Seems anywhere I see it for sale its just a "super locker".....
Old Oct 11, 2011 | 01:51 PM
SE5spd's Avatar
SE5spd
both.
Old Oct 11, 2011 | 02:00 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
1.5 way however it works differently then other LSDs. Research it, its dope.
Old Oct 11, 2011 | 02:23 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. why do you want 'true' coils?
2. $1100 is not nearly enough on a worthwhile set of 'true' coils
3. an LSD will cost more than $1100 with the required install parts, and especially if you have to pay for labor
The OS LSD doesn't actually work any differently from any other clutch type LSD. It is middle of the road in terms of noise/intrusiveness to the cabin, NISMO being the loudest, Carbonetics being the quietest. Carbonetics needs more frequent oil flushes and has been on extended backorder, OSG's are available in stock (we have 1 on the shelf as well as the install parts needed for it to go into the car). The OS is a terrific unit, but there are no bests between clutch type and helical..different means towards similar ends. The best choice for you depends on your realistic current uses for the car, and realistic future goals
Old Oct 11, 2011 | 05:28 PM
CTZ860's Avatar
CTZ860
Occasional track day...id like to be able to drift (not really possible now with my open diff) and of course drivin all the time on real windy *** roads. I was leanin toward 1.5 way bit im thinkin i culd get used to the 2 way. I wanna understand a lil more how it locks when decel in a corner but from wat i read if u are decel hard enough into a corner with a 1.5 way it can lock up....is this true?
Old Oct 11, 2011 | 05:34 PM
SE5spd's Avatar
SE5spd
http://en.wikipedia.org/wiki/Limited_slip_differential
if you are not drifting dont get a 2 way
Old Oct 11, 2011 | 05:42 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
http://www.osgiken.net/faqs.html
Old Oct 12, 2011 | 12:07 AM
terrasmak's Avatar
Unless your running a dedicated drift car, a 1.5 diff will be plenty for you.
