350z compression rod bush!!!!! Help
Old Oct 27, 2011 | 10:02 AM
secondaaaa's Avatar
secondaaaa
Question 350z compression rod bush!!!!! Help
I have a 2004 350Z that requires a compression rod bush. (front suspension)
Can someone please help me with regards to where I can buy one???
Many Thanks in advance
Phil
Old Oct 27, 2011 | 01:26 PM
DavesZ#3's Avatar
DavesZ#3
Besides the obvious place (a dealer), you can try one of the Vendors here...
https://my350z.com/forum/vendor_directory.php
... or post a WTB thread here...
https://my350z.com/forum/vendor-wanted-86/
Old Oct 27, 2011 | 01:49 PM
labelworkshop75's Avatar
labelworkshop75
If your car is stock I would just put another crap OEM one in. If you want to upgrade look at whiteline or SPL
Old Oct 27, 2011 | 02:25 PM
bmccann101's Avatar
bmccann101
yep, ebay.
Old Oct 27, 2011 | 05:59 PM
JDMStanced's Avatar
JDMStanced
SPL will produce loud noise going over small bumps like lane dots. But they are the best CR bushings
Old Oct 27, 2011 | 07:01 PM
terrasmak's Avatar
No problem with mine, load clunking noise went away once i properly installed adjustable endlinks.
Old Oct 27, 2011 | 07:59 PM
Shawz1102's Avatar
Shawz1102
What in the world...
$150 for SPL compression rod bushings?
The Whiteine one is only $50.....
Old Oct 27, 2011 | 10:14 PM
terrasmak's Avatar
Thats like complaining about the price between a diamond and a CZ.
Old Oct 27, 2011 | 11:53 PM
Wasso's Avatar
Wasso
The SPL bushes make a noticeable difference. They have greater ability to drive in Caster and as such your turning ability will be improved, as well as they'll last hell lot longer than oem. I also went for SPL ARB bushes which are very cheap and help with keeping the car flatter in corners.
The price might seem expensive but when you compare it to say coilovers the price isn't that bad. Not saying it replaces coilies, but def improves contact with the road. The Z should have been fitted with these as STANDARD!
Old Oct 28, 2011 | 09:02 AM
JDMStanced's Avatar
JDMStanced
what's spl arb bushings?
Old Oct 28, 2011 | 09:23 AM
bbs350z's Avatar
bbs350z
i needed to replace 1 on my old g35 sedan. just found a used z assembly and swapped it. if mine go on my z, ill definitely do the spl
Old Oct 28, 2011 | 09:33 AM
Shawz1102's Avatar
Shawz1102
Since i'm only DDing my car and could care less about performance, are there other options besides the SPL for compression rod bushing?
Old Oct 28, 2011 | 11:28 AM
nismonian's Avatar
nismonian
whiteline or even OEM^
Old Oct 28, 2011 | 12:29 PM
go kart's Avatar
go kart
i have energy ones, i like em
Old Oct 28, 2011 | 02:02 PM
B2autodesigns's Avatar
B2autodesigns
Vendor - Former Vendor
I have the Energy Suspension ones in stock.
Check the link:
https://my350z.com/forum/misc/538058...-in-stock.html
Old Oct 28, 2011 | 02:20 PM
Wasso's Avatar
Wasso
Anti Roll Bar (Sway Bar) sorry English terminology.
Old Oct 28, 2011 | 05:56 PM
Miko's Avatar
Miko
I love 'em! Got the inners,outers,and ctrl arm too
Old Oct 29, 2011 | 09:13 AM
Shawz1102's Avatar
Shawz1102
Sorry to high jack this thread again op, but :
How's the durability for the Energy and Whiteline compression rod bushings?
Old Oct 30, 2011 | 05:07 PM
go kart's Avatar
go kart
both are polyurethane so im pretty sure they will outlast a brand new oem rubber one by a good amount. all my bushings in the front are energy or whiteline and i love it. im about to get the energy set for the rear now
Old Oct 30, 2011 | 05:18 PM
labelworkshop75
If you dont care about performance and you are not lowered, and want to go the cheap route just buy another OEM one. If you want something better look at Whiteline. If you want to stunt hard buy the SPL.
