OEM Brembo Question
Old Nov 14, 2011 | 04:20 PM
GetIt's Avatar
GetIt
Default OEM Brembo Question
Does anyone know if there is a LARGER rotor upgrade for the OEM Brembos? Need something a little more than 12" to fill in the barrel gap on my LMGT4s. Thanks for your help ahead of time.
P.S. For you fire starters, I did search and came up with nothing.
Old Nov 14, 2011 | 04:59 PM
DavesZ#3's Avatar
DavesZ#3
Brembo GT would be considered an "upgrade" to the OEM brembos. Otherwise, you're looking at every other BBK.
It's not a pure rotor replacement, you'd be looking at rotors, calipers, pads, etc.
Old Nov 14, 2011 | 05:18 PM
jerseystyle's Avatar
jerseystyle
This^^^^ Think about where your calipers are mounted. Has nothing to do with rotors, so to just "upgrade" to larger rotors, you would have to have special brackets made to mount the calipers wider out (if that makes sense). Which I would NOT recommend doing!
Old Nov 14, 2011 | 05:20 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
What would a larger rotor accomplish? The pad size would still be the same.
Old Nov 14, 2011 | 05:31 PM
Waiz's Avatar
Waiz
This is a strange question...
Old Nov 14, 2011 | 06:11 PM
jerseystyle
I am gonna guess by his statement "Need something a little more than 12" to fill in the barrel gap on my LMGT4s" that it's strictly for looks. Doesn't make a whole lotta sense to me
OP: If you want larger rotors, buy a BBK
Old Nov 14, 2011 | 09:39 PM
Larger rotor? Sure but the position of the caliper is fixed. How does that work out?
Old Nov 15, 2011 | 04:04 AM
jerseystyle
That's an easy way to say what I was getting at
Old Nov 15, 2011 | 02:13 PM
trusovici's Avatar
trusovici
larger rotors make it easier to stop, has nothing to do with the size of the pad.
Old Nov 15, 2011 | 02:36 PM
AdvanZ33's Avatar
AdvanZ33
Using this picture as an example, I would guess the pad is using upwards of 80-90% of the rotors surface to stop. But what your saying is putting a larger, heavier rotor with the same caliper pushing the same size pad will stop better while leaving a larger percentage of the rotor surface untouched?
Old Nov 15, 2011 | 03:55 PM
GetIt's Avatar
GetIt
Ok, basically what i want to do is put a 14"-16" rotor(considering the oem rotor i believe is a 12" rotor), to fill in the gap between my caliper and barrel on my wheels. How is that a strange question? I know you'll need to relocate the caliper to accomodate the larger rotor, but going back to my original question does any company make a kit that will allow you to do so? This has noting to do with pad size. Same concept as adding a BBK to any oem vechile that doesn't have one. The OEM Brembo calipers will be sufficient to what i need them for, i basically want a larger rotor to fill in gap, no need to spend 3k+ just for that. I have a front bbk set of 14" wilwood rotors and wilwood 4 Pot Calipers, but would like to keep using my brembos because of the rear set-up.
Old Nov 15, 2011 | 04:43 PM
striker27's Avatar
striker27
Why not just powder coat the rear Brembos you already have to match the Wilwood front 14" BBK and be done with it??? It should work fine if not better then the stock set up and get you the look that you are after at the same time..
I think it is a win win...
Old Nov 15, 2011 | 06:05 PM
Waiz's Avatar
Waiz
The bigger rotor won't fit, don't even bother trying.
Old Nov 21, 2011 | 05:25 AM
trusovici's Avatar
trusovici
the increased radius of the rotor creates more leverage to stop. imagine your steering wheel was half the size, it would be more difficult to turn. now imagine it being twice the size.
Old Nov 21, 2011 | 05:37 AM
deeno's Avatar
deeno
You'll need a bbk....if you want to increase the rotor size and leave the oem caliper/pads you'll only be hurting yourself (hopefully not literally) since the pad will only cover a portion of the rotor
Old Nov 21, 2011 | 06:16 AM
trusovici's Avatar
trusovici
people do this all the time in the VW community. they have special made brackets that lets you mount the caliper out. Creating more stopping power. Once again the pad size doesnt matter.
Old Nov 21, 2011 | 06:31 AM
deeno's Avatar
deeno
Pic/info on that ?
Not to be an *** but Zs aren't VW and I've never heard of ppl doing that
Old Nov 21, 2011 | 06:42 AM
trusovici's Avatar
trusovici
info on what? its common sense. you ever try and stop a small rotating part with your hand? like a drill etc.? its very difficult. Now imagine stopping a larger diameter rotating part spinning at the same speed. its easier.
HERE YOU GO BUD
http://www.ecstuning.com/Audi-B5_A4-...rake_OEM/ES91/
And Can i Ask you what the manufacturer has anything to do with physics? Yes the Z isnt a VW....
Old Nov 21, 2011 | 08:48 AM
bbs350z's Avatar
bbs350z
eh just 14-16, no big deal.
i recommend selling the brembos and getting a set of g37/370z akebonos. large calipers, large pads, and upgrade to a better pad and your good to go. on the plus side they're fairly cheap too. all you need is the caliper adapter brackets
Old Nov 21, 2011 | 09:48 AM
350Zdj's Avatar
350Zdj
Makes sense. Never thought of that. But what about the added unsprung weight?
