OEM Brembo Question
yea, thats true, there will be more rotational mass, however the increased leverage outweighs the detrimental effects of the increased rotor size.
honestly the only real noticeable difference i felt when i upgraded to brembos and steel lines was the zero fade.
Ok, basically what i want to do is put a 14"-16" rotor(considering the oem rotor i believe is a 12" rotor), to fill in the gap between my caliper and barrel on my wheels. How is that a strange question? I know you'll need to relocate the caliper to accomodate the larger rotor, but going back to my original question does any company make a kit that will allow you to do so? This has noting to do with pad size. Same concept as adding a BBK to any oem vechile that doesn't have one. The OEM Brembo calipers will be sufficient to what i need them for, i basically want a larger rotor to fill in gap, no need to spend 3k+ just for that. I have a front bbk set of 14" wilwood rotors and wilwood 4 Pot Calipers, but would like to keep using my brembos because of the rear set-up.
You learn something new I guess
And no on the drill....
info on what? its common sense. you ever try and stop a small rotating part with your hand? like a drill etc.? its very difficult. Now imagine stopping a larger diameter rotating part spinning at the same speed. its easier.
HERE YOU GO BUD
http://www.ecstuning.com/Audi-B5_A4-...rake_OEM/ES91/
And Can i Ask you what the manufacturer has anything to do with physics? Yes the Z isnt a VW....
HERE YOU GO BUD
Since this is an oem brembo question thread:
I installed my rear calipers and snapped the bolt that hold the brake line into the caliper...
My question is can I cut the stock non brembo bolt to the size of the other bolt and make it work?
