I Need a Rear Cradle Measurement
Old Nov 26, 2011 | 04:27 PM
overZealous1's Avatar
overZealous1
Default I Need a Rear Cradle Measurement
i am putting a 350z rearend into a 67 camaro, and need to know factory installed height of rear cradle. so if your car is stock or lowered, i just need the height of the lower camber bolt centerline, to the ground. if you are lowered, just tell me how much and i can add it back in. thanks.
rear toe link (spring bucket one) will work just as good, just make sure to let me know which one you measured. again, bolt height on cradle, not where they bolt to rear spindle.
Old Nov 26, 2011 | 06:32 PM
natedogg713's Avatar
natedogg713
kinda unrelated but do you have a build thread for this project? z rear in a old school camaro? i gotta see the rest of the project.
Old Nov 26, 2011 | 07:34 PM
overZealous1
i do over on a protouring site. it has a twin gt35r turbos on an 2008 ls2 with viper 6 spd. adv1 19x10 and 20x13 forged monoblocks, front zr1 brakes, all new aftermarket front suspension. the 350z rear will be a great addition to the car. i am starting with a bare shell, so a long ways to go. turning the car into full frame, and am ready to get going on it, just need this one measurement! a local guy has been flaking on me for 2 weeks. hoping to start tomorrow cutting.
will keep the stock ecu and drive by wire.
Old Nov 26, 2011 | 07:42 PM
natedogg713
that setup sounds pretty insane, if i was near my car id get those measurements for you. if you have a few mins care to educate me why the z rear is a good choice for your project?
Old Nov 26, 2011 | 08:03 PM
overZealous1
well i built a built motor tt nitroused halteched 350z years ago. i know it will take abuse. the geometry is not real hot for straight line take off, but great in the turns. a compromise i am willing to have. with 345 rears, it will still stick good.
i have replaced all my links in the rear already with aftermarket adjustable stuff, and higher hp axles are available for it too. so for aftermarket support, upgradeability, and the handling and feel, it is a great choice over a solid rear axle.
now, the best part. the 350z rear is the easiest swap to do because everything including the sway bar is all hooked to the rear cradle. 4 bolts hold the whole rear suspension in. i deleted the rear spring buckets and am going to run coilovers, so those will just tie into the roll cage or turn it into a push rod/rocker type and lay them flat. the bolt holes are super close to my front subframe centerline, so i am making full rails and tie in the front subframe also. a 12 point cage will tie the whole thing together. can't wait!!
Old Nov 26, 2011 | 08:18 PM
terrasmak's Avatar
Just set it up with the arms level at the ride height you want. You can easily set it up for the perfect Look and rollcenter.
Old Nov 26, 2011 | 08:46 PM
overZealous1
that would work starting from scratch, or making new upper a-arm mounts. just looking for factory installed height. my tolerances are very close. new frame will be channeled in and setting body 3" off ground at my CORRECT suspension geometry height. i do not believe nissan set the lower straight, maybe all 3 links average out to straight, but a simple measurement is all i need. looking to set the Z rear at 1.5" lower than stock to increase my camber gain since my springs will not allow much movement.
Old Nov 26, 2011 | 10:47 PM
terrasmak's Avatar
I wish i could help , i really have no idea what my car is acually dropped. It's is around 1 to 1.5 inch to level the arms. The spring bucket arm and toe arm are level about that point, that would be the CORRECT height for the subframe you are using. All you have to do is mount it at its corresponding location in your chassis.
Something as serious as yoru building, i would swap to the G37/370Z subframe and also mod the pickup points a bit.
Old Nov 26, 2011 | 10:59 PM
overZealous1
i already have every last piece i need to install it, minus this one measurement. not moddifying it at all. i loved the way the Z handled, thats a big reason i chose this rear outside of corvette, cobra, viper,custom made, etc. i know what it can do just as it sits.
Old Nov 26, 2011 | 11:03 PM
overZealous1
200 views and nothing? lol.
Old Nov 27, 2011 | 06:46 AM
winchman's Avatar
winchman
I just measured my '08 touring coupe at 10 5/8" with a quarter tank of gas. Here's a picture.
Attached Thumbnails I Need a Rear Cradle Measurement-miscellaneous-cannon-november-2011-on-006.jpg
Old Nov 27, 2011 | 09:23 AM
overZealous1
winchman, you are da'man!!!! thanks for taking time to do it and a pic too. what size tire are you running?
edit, read your sig, im guessing its the stock 245/45/18?
Old Nov 27, 2011 | 10:07 AM
winchman's Avatar
winchman
That's correct.
Here's a link to the thread on the project:
http://www.pro-touring.com/showthrea...rend-67-camaro
Looking forward to seeing more.
Old Nov 27, 2011 | 11:29 AM
overZealous1
thanks man. i forgot i have some stuff to do today, so will be tomorrow i will make stand offs to set the rear cradle at correct height, and start cutting frame rails!!
if ya look under my name at that same site, you will see the engine build thread. actually, i think i even put one here in the nw section!!
