Help removing OEM rear toe bolt for SPC
Old Jan 14, 2012 | 02:46 PM
Arvin89's Avatar
Arvin89
Default Help removing OEM rear toe bolt for SPC
Okay so i read through the suspension 101 and many other threads with pictures describing how to remove the oem toe bolt. I put in the adjustable camber arms no problem.
Toe bolt:
1)Raised rear spring bucket with jack to reduce load on it
2)Got the oem toe bolt nut off
3)Manually and air tool ratcheted the toe bolt to remove it, but it wouldnt come out.
It would move outwards just a little then come back forward. While i was trying to remove it the car/spring bucket was moving back and forth (adjusting the toe i presume as the bolt was spinning).
But again the bolt just would not come out or even move very far out.
Any suggestions on what to do here? I searched the forum and google, seems like im the only person that wasnt able to get the bolt out...
Thanks
Old Jan 14, 2012 | 03:23 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Is the car in the air on jack stands already with wheels off of the ground?
Old Jan 14, 2012 | 03:30 PM
Arvin89's Avatar
Arvin89
Yes, i had the car on jack stands with the rear wheels up off the ground only, fronts were still down.
Old Jan 14, 2012 | 03:38 PM
SparkleCityHop
Living in 350Z
When I've removed them each time, after the rear was in the air, I just lifted the jack until it was touching the spring bucket & not enough to apply any pressure. This was mainly to keep the spring from pushing the bucket/arm down as I removed the toe bolt. (Danger of stripping bolt and danger getting hurt when releasing that much load from the spring and bucket all at once if you don't.)
I then removed the nut, and used a rubber mallet to knock the bolt through, then used a short pry bar to pop it the rest of the way out. Since it was an eccentric and because of placement, that was easier for me than using wobble sockets and extensions on my air tools. I'm not sure what the pros do, but that worked pretty good for me, and I've removed mine at least 5 or 6 different times.
Old Jan 14, 2012 | 03:45 PM
Arvin89's Avatar
Arvin89
Ill give the rubber mallet a shot next time. Do you, or anyone, know if the spring bucket bushing? is threaded? Id assume its not since you hammered the bolt through.
Thanks for the tips.
Any other ideas are still welcome.
Old Jan 14, 2012 | 05:32 PM
terrasmak's Avatar
Remove the spring bucket bolt on the spindle side first, then remove the toe bolt.
Old Jan 14, 2012 | 06:13 PM
Swiffer's Avatar
Swiffer
^ thats what I did. I loosened both bolts first and then removed the one closest to you first. The toe bolt came out pretty easily. Didnt really have to bang it out.
StateNuke08
Oct 31, 2015 05:01 AM
emooheo
Oct 14, 2015 08:58 AM
CJs_Z33
Sep 18, 2015 12:06 PM
Suffolk350z
Sep 13, 2015 02:43 PM
PureR3d
Sep 10, 2015 06:23 PM
