Sway bar's influence on overall RC
Old Jan 20, 2012 | 04:01 AM
QTB's Avatar
QTB
Default Sway bar's influence on overall RC
I'm looking at possibly doing some new front or possibly rear springs to balance out my Z with the addition of the LS2. My main question is does anyone have an actual equivilent spring rate of a stock sway bar?
From what I've seen based on some very very loose calculations and making an approximation of what my weight distribution is, I'm thinking my current hotchkis on 3 of 4 settting (4 being softest) it adds about 20% front roll couple bias or 11-12kg/mm at my current full deflection in mid corner.
Obvioiusly once it's all buttoned up and road worthy it will get scaled and corner weighted but, I'm bored and a nerd so I'm just looking for info I couldn't find in a search.
Last edited by QTB; Jan 20, 2012 at 08:20 AM. Reason: changed numbers to match my later findings
Old Jan 20, 2012 | 07:09 AM
QTB's Avatar
QTB
Nevermind I found some info on the Hotchkis site
350Z & 03- 05 G35 Front
Hole 1 = 1525 lbs/in (22% Stiffer than stock)
Hole 2 = 1845 lbs/in (48% Stiffer than stock)
Hole 3 = 2270 lbs/in (82% Stiffer than stock)
Hole 4 = 2855 lbs/in (129% Stiffer than stock)
Now I just need to figure out the motion ratio of the sway bars
Old Jan 20, 2012 | 10:20 AM
ronn1's Avatar
ronn1
Those #s are based on EARLY Z Models (03-04). Keep in mind 04.5+ models had a suspension revision and the front bar was increased by 17% over the previous models. Hotchkis has those #s as well..I think the #1 setting is actually SOFTER than the revised bars (instead of 5% stiffer).
Old Jan 20, 2012 | 11:25 AM
QTB's Avatar
QTB
Ah good to know, thank you.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
