Need general Suggestions on getting minimum camber wear
Old Jan 27, 2012 | 01:21 PM
Stance350zee's Avatar
Stance350zee
Default Need general Suggestions on getting minimum camber wear
Well i just spent 800.00 on tires pretty much. And my car is lowered on coilovers and i want to now what i need to do to make my tires last aslong as possibble. I am running work varianza t1s 19 x 9.5 and 19 x 10.5 and am running stretched tires and will be sitting pretty low. So your help is appreciated
Old Jan 27, 2012 | 01:25 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Adjustable camber arms.
Old Jan 27, 2012 | 01:49 PM
bmccann101's Avatar
bmccann101
its usually toe that wears the tires on our cars btw.
Old Jan 27, 2012 | 02:04 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Camber arms and get a DD!
Old Jan 27, 2012 | 02:06 PM
Stance350zee
explain toe a little bit please
so camber arms on on the list .. cheap ebay ones work or not a good idea
Old Jan 27, 2012 | 02:12 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Wait, you really haven't read up on this have you?
I suggest you go to the suspension section and read the stickies and stay out of the Agressive thread for a second!
Old Jan 27, 2012 | 02:25 PM
BoomerZ33's Avatar
BoomerZ33
not a good idea. SPL makes high quality suspension parts.
READ:
https://my350z.com/forum/brakes-and-...ion-101-a.html
Old Jan 27, 2012 | 03:11 PM
Stance350zee
you caught me, i been looking at the fun stuff
READ:
thanks man i read that .. so the toe bolt can be ordered from spc i guess and i am now wanting the spc camber arms
Old Jan 27, 2012 | 03:37 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Lol nothing wrong with looking at the end results...just know it's definitely a lifestyle and something you can't halfa$$. Well you can but everyone in that scene will point you out quickly!
Old Jan 27, 2012 | 03:44 PM
Stance350zee
well so far i found the rear spc's for 160.00
and the fronts for i think 400
I def want the caster and camber adjustments
anyone know cheaper place to buy ?
Old Jan 27, 2012 | 06:48 PM
terrasmak's Avatar
You want the HellaGay look, you have to pay the HellaGay price.
Poked , stretched and slammed is expensive to be trendy.
Old Jan 27, 2012 | 09:56 PM
Well lets see. Put the car back the way it was before you made it a lowrider.
Old Jan 27, 2012 | 10:07 PM
sdZ33's Avatar
sdZ33
Wait, your SN is "Stance350zee" and you know nothing about teh "Stance"???
Old Jan 28, 2012 | 08:35 AM
PeterFromSDiego's Avatar
PeterFromSDiego
^ LMAO. Let's be nice guys.
Look into SPL/SPC rear camber arms, the fronts are recommended too. But if you're penny pinching, you can get away without them.
You can adjust your camber within OEM specs (depending on the stretch of your tire and if it rubs, etc.)
You can buy higher tread tires.
And what Boomer said, read that sticky thread. Before I dropped my car I made sure to read it, then re-read in more detail then do a search.
Old Jan 28, 2012 | 08:49 AM
Stance350zee
your hellastupid if you cant show respect in someones thread that has nothing to do with you
no thanks. But worry about your car not mine
no still learning lol ... my old gs was on springs and i didnt have camber issues. this is my first drop this low
yeah i should read more about it. I just am in a rush to fix my car up cuz i am getting maried soon and my wife will probably scream if she finds out how much money i spend on my car. And i plan on doing it the right way so i am going with fronts as well i just want to know if someone knows where the best price is for spc front and rears
Also i am getting a tapping sound in the rear. Is it my brake line getting hit by the tire or could it be the shock ? we made sure everything was tight already
Old Jan 28, 2012 | 09:28 AM
Stance350zee
Update: Just purchased spc front camber arms with caster adjustment Paid 375
Old Jan 28, 2012 | 12:40 PM
L-Fab's Avatar
L-Fab
*Aftermarket Front A Arms
*Aftermarket Rear Camber Arms
*roll your rear fenders [so you can get into spec range without/minimal rubbing]
*Aftermarket Toe Bolts
*Lockout Washers [not necessary, but will ensure your rear camber alignment doesnt go anywhere]
FYI: your Lower Control Arm and Radius Arm bushings are going to blow due to the lowering of your vehicle. They're probably already blown by now. Suggest replacing before alignment.
Here's some info about your bushing choices:
https://my350z.com/forum/brakes-and-...hing-data.html
Old Jan 28, 2012 | 01:07 PM
Stance350zee
going to get rear camber arms .. hunting for a set now .. if you know a good vendor that will do less than 160(i may be able to get them fro less) for a pair of spc let me know
gotta look into a arms
toe bolts are the uncentered washer right or is that the bolts that come with the camber arms ?
(new to this)
the contol arm bushings and radius arm bushings you have those ?
where do the lockout washers go ?
Old Jan 28, 2012 | 01:33 PM
L-Fab's Avatar
L-Fab
We sell rebuilt arms that are powdercoated and have the bushings pre-installed, with a core exchange program
https://my350z.com/forum/suspension/...sion-arms.html
The lockout washers replace the eccentric camber bolts [off center bolts that are at the end of the camber arm].
You will no longer need the eccentric bolts due to you getting the aftermarket camber arms, which have far more camber range.
The purpose of deleting the eccentric bolt is to eliminate the ability of that bolt from moving under high stresses, which in turn would throw off your alignment.
https://my350z.com/forum/suspension/...t-washers.html
Old Jan 28, 2012 | 02:16 PM
Stance350zee
First of all thanks for your suggestions. I don't think i want to replace the bushings just yet unless your going to give me an insane price on them. Ill wait 6 months or so on the stock ones. My car has 57k miles and it was dealer maintained. PM the best on whiteline both
Second - why would one choose spc eccentric bolts over your product ? and would i need one pair or two pair ?
