Alignment with SPC KIT and Eibach Pro-Kit...HELP!!
Old Feb 9, 2012 | 06:35 AM
wadhah's Avatar
wadhah
Default Alignment with SPC KIT and Eibach Pro-Kit...HELP!!
OK heres the thing i have a pro kit installed in my car and the SPC camber/toe kit, simply put . does any body know if you can get the toe to 0 and the camber close to - 0.5, cuz i sure cant and its bugging me , i need to save tires drifting!!
Thanks guys.
Old Feb 9, 2012 | 07:47 AM
PrimeX's Avatar
PrimeX
Wrong forum, try here.
https://my350z.com/forum/brakes-and-suspension-399/
Old Feb 9, 2012 | 08:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You have toe bolts and camber arms right? When I needed more adjustability I also used traction rods. With an avg drop I couldn't get more positive than -1 in the rear while keeping toe in spec.
Old Feb 9, 2012 | 11:24 AM
kevin3fittyz's Avatar
kevin3fittyz
I had the same problem... kinda annoying. I have the sportlines(1.2" drop) on mine and got the camber kit w/ toe bolt and couldn't get it any more positive than around -1.3. The wheels seem like they are leaning pretty far inward though i think this is around factory spec?
Old Feb 9, 2012 | 12:28 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I believe factory spec in the rear is -1.1 thru -1.6
Camber always looks worse on skinny tires/factory/weak offset wheels too.
Old Feb 9, 2012 | 12:55 PM
oscatipo's Avatar
oscatipo
I have the same setup as the OP. best you can do is slightly more camber than factory spec.
Old Feb 9, 2012 | 06:30 PM
terrasmak's Avatar
OEM camber is -1.1 to -2.1 and the cars typically sit around -1.8 from the factory.
Old Feb 9, 2012 | 06:44 PM
FATPUBUS's Avatar
FATPUBUS
Ditch the crappy spc arms!
Old Feb 10, 2012 | 06:17 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Camber by itself won't kill the tires, Any toe out will with negative camber will. Keep the toe in check and you'll be fine with some camber.
Old Feb 10, 2012 | 10:24 AM
terrasmak's Avatar
I guess you didn't bother to read the "while drifting part" typically drifters who are not part of the hellagay movement run the rear camber between 0 and -0.5 to keep from burning off just the inside of the tire.
Old Feb 10, 2012 | 12:48 PM
ZSpeedPerformance
Ya, missed that part.... Check!
Old Feb 10, 2012 | 04:17 PM
kevin3fittyz
hahah hellagay movement
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
