Crazy ride after spring install today!! Plz help
Old Feb 10, 2012 | 08:15 AM
Waiz's Avatar
Waiz
Put in the fronts OP as everyone has said and your problems will go away.
I had only the rears done for a few days and it was a very weird floaty feeling as well driving around town.
Old Feb 10, 2012 | 09:38 AM
shayan89's Avatar
shayan89
Before I get my alignment, what do ya think of a little negative camber? Like -2 degrees.
Old Feb 10, 2012 | 09:42 AM
FATPUBUS's Avatar
FATPUBUS
Not needed, if you have a really good impact you can launch the strut approximatly 1 inch when you lay the strut on the side and zip the nut off.
Warning 370z and G37 will launch the strut, you need compressers to remove and install these springs.
True! i just used an impact to take the oem springs off. then I then put the new spring on the strut, and used a floor jack under the lower arm to get the strut shaft back into the upper mount and impacted it on. Takes a little working with, but still pretty simple
Old Feb 10, 2012 | 10:20 AM
terrasmak's Avatar
I push down on the spring with my hand and install the nut, then impact it on. Its really easy to do, i'm not a bodybuilder and only weigh 170.
Old Feb 10, 2012 | 01:11 PM
03redlineZ's Avatar
03redlineZ
Originally Posted by taywan
Where u located in SC 03redline??
Im in Lexington SC.
Old Feb 10, 2012 | 01:14 PM
03redlineZ's Avatar
03redlineZ
Fixed for you
Hey Terrasmak, i wasnt trying to argue with just to let you know i just wanted to tell the OP all the precautions. If you got your front springs off without a spring compressor i totally believe you i just wanted to prepare the thread starter with safety ideas.
Conway_160
Drag
Sep 29, 2015 08:07 AM
