Energy Suspension Rear Diff Bushing
Old Mar 10, 2012 | 01:45 PM
fairladylover's Avatar
fairladylover
Default Energy Suspension Rear Diff Bushing
Did some searching but only found info for the solid bushing install.
Does the sleeve have to be reused w the poly bushing?
or does the bushing go in by itself.
still searching. all help is appreciated.
thanks
Old Mar 10, 2012 | 05:25 PM
vq35deZ's Avatar
vq35deZ
yes you reuse the sleeve from your original mount
Old Mar 10, 2012 | 05:31 PM
fairladylover
thanks for the reply
so is it even necessary to press it out?
Old Mar 10, 2012 | 05:40 PM
steidz's Avatar
steidz
Here are a few pic of mine. You will reuse the inner one.
https://my350z.com/forum/9440483-post21731.html
easiest to cut the bushing out and clean up the inner bushing.
Old Mar 10, 2012 | 06:32 PM
fairladylover
oh ok.
so only the inner sleeve will b reused and not the outter. i have to take the outter one out?
i was confused from the first reply.
Old Mar 10, 2012 | 10:46 PM
vq35deZ's Avatar
vq35deZ
remove the whole oem bushing from the subframe, its a pain to get it out. once its out cut out the center sleeve out to reuse it with the energy poly bushing, you will most likely have to remove excess rubber from the original sleeve to be able to push it into the energy bushing ....
Old Mar 10, 2012 | 10:50 PM
fairladylover
also, im trying to bang out the bushings in the ears of the diff w a socket and they are not budging. Is this method done from the top or the bottom. i saw on another post that they should hammer out but i am having no luck.
thanks
Old Mar 11, 2012 | 12:18 AM
gabe3d's Avatar
gabe3d
Not sure if you saw this
https://my350z.com/forum/engine-driv...mp-either.html
Old Mar 11, 2012 | 08:03 AM
steidz's Avatar
steidz
thanks
If I remember one side of the bushing on the diff. has a shoulder. I think it is on the top side so you need to turn the diff upside down and pound away. Take a big hammer to it. Also dont forget to plug the diff drain tube with a screw or you'll have a mess.
pr_350z
Oct 1, 2015 05:03 PM
