Reason behind putting load on a-arms before torquing them?
Old Mar 19, 2012 | 07:38 PM
braydo25's Avatar
braydo25
Default Reason behind putting load on a-arms before torquing them?
So here's a quick question, I have spc a-arms that I installed a few weeks ago, but I didn't put full load on my suspension before torquing the 2 bolts up that hold them to the car / frame. I'm wondering if this is why they clunk occasionally?
Also, what is the point of putting full load on the suspension (jacking the suspension up from the hub until fully compressed) and then torquing down the arms??
Old Mar 19, 2012 | 07:44 PM
JPsZ's Avatar
JPsZ
Are the bushings you're torquing rubber? If so, I'd assume you want to torque them near the position is which the arm will be in most of the time, not fully extended. Otherwise the rubber would be stretching in neutral stance.
Old Mar 20, 2012 | 12:14 AM
AngelsVQ's Avatar
AngelsVQ
Correct. You can actually tear the bushing if tightened before load. Spc is know to "clunk", is it hitting the top?
Old Mar 21, 2012 | 02:33 AM
braydo25's Avatar
braydo25
It's clunking, but I've compressed my suspension completely while jacked up on both sides to double check for anything hitting, and it doesn't look like it's my a-arms that are making the clunking noise?
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
