FML.. Caliper Bolts Suck...
Old Apr 7, 2012 | 08:23 PM
LauGhNoWQQLaTeR's Avatar
LauGhNoWQQLaTeR
yeah i bought a breaker guys, i forgot to get some liquid wrench but ill make sure to get that too before i make my next attempt, cant do it this weekend because of easter and all.. and to answer that question about me doing it the wrong way... no i was using a rachet so i was not going the wrong way.
thanks for all the help guys and ill let u know how it goes when i get the time to go do it.
Old Apr 7, 2012 | 08:47 PM
ronn1's Avatar
ronn1
You need to have adequate space for a large breaker bar. That means jacking the car up to allow for clearance. You may want to add more torque by slipping a hollow pipe over the bar...extending the lever. You will have to grab the bar from below where you have enough reach to clear the body...know what I mean?
Old Apr 8, 2012 | 03:39 PM
Ak48z's Avatar
Ak48z
Going to try to tackle these on Friday, with an el cheapo harbor freight impact and pb blaster... and a breaker bar if needed. Will post back results.
Old Apr 8, 2012 | 04:16 PM
gzrecoil's Avatar
gzrecoil
Sorry, didn't read the posts.
This is what I did.
Car up on jack stands, put a craftsman open end wrench(24 mm idk?) on there facing in so the wrench wouldn't fall off, in an up position.
Layed on the ground and pushed with my foot until it came off, kind of had to pull against the car so this is NOT SAFE, but it worked.
If pushing doesn't work try actually kicking it if you can get the angle, I couldn't, but a faster kick would probably brake it loose easier.
Edit: Breaker bar or impact wrench is the way to go(I went back and read the thread lol)
Old Apr 9, 2012 | 12:09 AM
Jairen's Avatar
Jairen
I did mine and it is so much easier with a lift. A large breaker bar and it came loose right away.
When I did it without a lift, I used a cheap electric impact from Lowe's for cheap. Best thing ever without spending too much.
Old Apr 9, 2012 | 03:22 AM
white boy's Avatar
white boy
Originally Posted by Bret86944
So is buying a breaker bar not an option? It's kinda of a necessity...
^ exactly what he said
Old Apr 9, 2012 | 04:36 AM
phreaktor's Avatar
phreaktor
Design Engineer
Let it sit for a year or two and lift some weights.
Old Apr 13, 2012 | 08:34 PM
LauGhNoWQQLaTeR
success, stepping on the breaker bar with pb blaster broke the fronts, the rear rotors ended up coming off pretty easy as well with some pb blaster and prying. thanks guys.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
