Used BBK - need advice :(
Old May 11, 2012 | 07:51 PM
R6n350GT's Avatar
R6n350GT
Ok so removed all pistons and seals from rears and the dust seals all broken, but the other seal is perfect...
Front is opposite, dust seals perfect but looking at pic below would you say the other seal is on the way out?
Question: how do you get the middle piston out? I see the left and right ones moving but the middle one is not coming out like the others... any suggestions?
Old May 12, 2012 | 12:08 AM
R6n350GT's Avatar
R6n350GT
Will these work since i have got it all apart and should be bleeding regularly for track ?
http://www.oakos.com/Merchant2/merchant.mvc?
Still need help with getting middle pistons out of the front calipers
Old May 12, 2012 | 04:05 PM
thekinn's Avatar
thekinn
Re-Install the other two pistons and then block them off with something (pieces of wood..?) then blast in some air and the stuck one will get all the pressure and come out. You may need a c-clamp or something to hold in the middle piston on the other side.
Old May 13, 2012 | 02:39 AM
R6n350GT's Avatar
R6n350GT
Good idea! I will try that tomorrow
I hope Kyle gets back to me also...
Those speed bleeders do i need the master cylinder pump thing with these?
And when i get my alignment done what toe and camber should i ask for for my setup ?
Love this forum, ill post pics asap.
so far my almost cleaned calipers (ill have to get the rest sand blasted and then powder coated)
Old May 13, 2012 | 04:06 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
looking good
Old Oct 27, 2012 | 11:42 AM
hugo350z's Avatar
hugo350z
any updates OP? How much were your seals and where did you get them from? I think I am going through the same thing. I bought some used ap racing (exact ones like yours) and for the life of me, my pedal won't get hard and I already bled through three motul rb600 bottles
Old Oct 27, 2012 | 11:52 AM
terrasmak's Avatar
Once I get to clean fresh fluid I clean my catch container and recycle fluid on an initial bleed. Much cheaper and allows you to do it with one bottle. Pressure bleeder is really needed. Can be done without, but takes a long time.
Old Oct 27, 2012 | 05:34 PM
hugo350z's Avatar
hugo350z
Gotcha I have a Vacula(mighty vac, same thing I guess), but my compressor is too small so I am looking into the pressure bleeder(Like the one Jason had). Also terrasmak, any specific vendor you recommend for replacement parts? Seems like stoptech and rotora have way more third party support than Ap
liqalu04
Jan 2, 2022 12:58 PM
