2007 350Z nismo Z shocks on '04 Z
Old May 26, 2012 | 09:29 PM
touge_drifter's Avatar
touge_drifter
Default 2007 350Z nismo Z shocks on '04 Z
friend put air ride on his '07 350Z nismo. offered me his nismo shocks and springs. will fit on the '04 w/VCD? and are they a good choice for $400?
thanks
Old May 26, 2012 | 09:49 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Is your friend on this site? Pics of this nismo.....either way I gave my stock suspension away to a friend with an 06...it will fit.
Old May 27, 2012 | 03:34 AM
2000atlanticgt's Avatar
2000atlanticgt
Yes, they will fit just fine:
https://my350z.com/forum/brakes-and-...ack-model.html
How many miles does he have on them? If they are in great shape, low miles I would say from personal experience they are well worth $400. If they have much more than 20k miles on them I would pass and start looking at other options.
Old May 27, 2012 | 09:26 AM
ronn1's Avatar
ronn1
thanks
They will fit fine..car will be at stock ride height..maybe a tad higher?.... and VERY stiff ride.
Old May 27, 2012 | 02:07 PM
Itzcashew's Avatar
Itzcashew
It will fit.
From what i understand the stock nismo suspension is the same as every other Z. IT's the S-Tune that is a different spec.
Old May 27, 2012 | 05:26 PM
ronn1's Avatar
ronn1
Originally Posted by Itzcashew
It will fit.
I have S tune right now..fits..and is MUCH more user friendly with rates. Also LOWERS car about 3/4"
Old May 27, 2012 | 08:00 PM
touge_drifter
Thanks, I just wanted something until i decide on a coul over to use. they have around 15-20K miles. I believe hes on here.
Old May 27, 2012 | 08:06 PM
lgear080's Avatar
lgear080
oh//// so that's how you ruin a nismo
Old May 27, 2012 | 08:33 PM
Itzcashew's Avatar
Itzcashew
So he degraded his nismo? Good thing your car will be done right
Old May 27, 2012 | 08:44 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Retarded
Old May 27, 2012 | 08:56 PM
erodriguez's Avatar
erodriguez
buy the shocks and then buy the car so you can rescue it from further torture.
and why is his 350z emblem on the wrong side....?
Old May 27, 2012 | 09:37 PM
KingBaby's Avatar
KingBaby
Hardest Setting
while he's at it trade for his brembos/tailights/seats/nismo braces....since he's on air those things are of no need to him
Old May 27, 2012 | 11:34 PM
Itzcashew's Avatar
Itzcashew
You know you can always sell them to needy my350zers
Old May 28, 2012 | 04:52 AM
2000atlanticgt
It will fit.
Wrong, 2007-2008 Nismo spring rates are much different and even slightly stiffer than the S-tune. Take a look at my link above if you want to see the spring rates.
Edit (to save you the effort of clicking on the link):
Nismo Z (2007-2008) linear front progressive rear
No drop front or rear
Spring rates 492/336-672
Nismo S-tune shock and spring setup 350Z
.6"/.6" drop
Spring rates 393-448/254-504
2003/2004 OEM 350Z linear front and rear
314/342
Old May 28, 2012 | 09:34 AM
ronn1's Avatar
ronn1
.6"/.6" drop
314/342
slightly stiffer than the S tune?
Take another look
I understand you can't use those shocks with any aftermarket lowering springs either, because the shocks won't work properly with em. I actually swapped out my REAR S tune springs, because I felt they were too stiff (504) on uneven pavement and actually caused tail to snap out on throttle in mid turn. I put in Eibach ProKits in rear (421) and they work great now with S tune shocks. Car launches a LOT better and no more power oversteer
Old May 28, 2012 | 02:53 PM
Itzcashew's Avatar
Itzcashew
.6"/.6" drop
314/342
I was talking about the design setup and ride height, not spring rate.
Old May 28, 2012 | 07:10 PM
2000atlanticgt
Originally Posted by ronn1
Take another look
I have been very happy with the change from the the stock 2003 suspension to the 2008 Nismo springs/shocks. I have driven both S-tune and the Nismo set-up and so far prefer the 2007-2008 Nismo but will let you know for sure after our next track day.
Old May 28, 2012 | 07:19 PM
2000atlanticgt
Ok, but your statement was vague and could mislead some people so I just added the details to clarify the 2007-2008 Nismo suspension is not "the same as every other Z."
Old May 28, 2012 | 08:07 PM
ronn1's Avatar
ronn1
As long as you have shocks and matching springs, it should perform very well.
It's going to be very stiff. Keep in mind, Nismo has stiffer body stucture as well to match the suspension set up. I didn't like the very stiff rear S tune set for reasons I mentioned. It's MUCH better (S tune) with softer rear springs (basically revised stock)..just my take. BTW, if you don't like the rears on your set up, I have the S tunes (504) that I took off mine and could sell you if you're interested.
Old May 28, 2012 | 08:21 PM
Rocknthehawk's Avatar
Rocknthehawk
wow...I have a bagged car, and I'm having a really hard time liking that.
