New Wilwood Big Brake kit for 350z
Old Jan 7, 2004 | 05:22 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
are there dust seals?
Old Jan 7, 2004 | 07:53 PM
azrael's Avatar
azrael
for the rear kit, does it retain parking/emergency brake functionality?
Old Jan 8, 2004 | 10:56 AM
DocofMind's Avatar
DocofMind
Mike, im sorry i wasnt more clear. The picture of of the 350Z rotor that we used hat the prototype hat on it which was NOT anodized. The final product will be anodized. We usually do the 14" rotor hats a dark tan color like the S2000 picture and he 13" rotor hats in black. If you prefer a specific color, it can be done
Old Jan 8, 2004 | 11:46 AM
DocofMind's Avatar
DocofMind
More great questions
The myth thats been circulating regarding Wilwood caliper s and dust seals is exactly that, a myth. Even without the dust seals they do not need yearly rebuilds or anything of the sort. I have been running Wilwood calipers on 4 of my own vehicles and none have required rebuilds. 2 of them get tracked regularly again without any issues. There is one simple maintnance procedure to do between pad changes and thats all to ensure long inner piston seal life. All you need to do is to clean the exposed area on the piston before pushing them back into the caliper with some scotch gaurd and you are set to go. Thats all.
Now, for those who are still in fear of calipers without dust seals, Wilwood has now developed a few new calipers that do have dust seals. They have a 4 piston caliper with the same shape and outer body as the 6 piston pictured above that does have the dust seals. This is merely a political move. Only to silence the critics. They did this to show that they can make calipers with dust seals, not because they needed to.
Old Jan 8, 2004 | 11:54 AM
DocofMind's Avatar
DocofMind
This is going to be another distinction between our Wilwood kit and other Wilwood kits. As with the others, our kit WILL retain the OEM emergency brake assembly. This keeps everything as an easy plug and play installation. No need for any type of retrofitting.
What is going to be different is the rear caliper. Every Wilwood kit I have seen up till now for the rear of the Nissans utilizes Wilwood old Billet Dynalite caliper. The caliper works fine but is not aesthetically pleasing. Its too small and shaped wierd and does not match the front caliper. Our kit is going to use the newest calipers that Wilwood makes which uses the exact same body as the large 6 piston caliper pictured. They are externally identical. Internally, they use smaller and correct piston diameters to retain the correct pedal height, feel and bias as the factory set up. The other advantage of using this larger caliper is that it also uses a larger brake pad. This is critical for the Nissans because of their factory bias. The rear of these cars actually does a lot of the work and is easily overheated at the track. The larger surface area of the pad will help alleviate much of this.
Old Jan 9, 2004 | 05:16 PM
N4Spd's Avatar
N4Spd
Default add me
please add me to the group buy for:
- 4 wheel set
- red calipers
- slotted rotors ONLY
- for g35 coupe 18" oem wheels
thanks,
rob
Old Jan 9, 2004 | 09:15 PM
Jeff@Evolution's Avatar
Jeff@Evolution
Interested
ZU L8R
iLLestJrz
ZxRage
ElvishasaZ
azrael
mickey
ColecatZ
Participants
Mapleleaf
N4Spd
J-dawg
If I forgot anyone. Please let me know, and I'll add you to the list. On the first shipment. We will only have 5 kits available. And the Red calipers are extra $100 for the pair.
Thank you
Jeff - Evolution
703.961.9090
Old Jan 10, 2004 | 03:32 AM
MSOsr's Avatar
MSOsr
Why are reds $100 more?
Old Jan 10, 2004 | 07:08 AM
Jeff@Evolution
Because it's not done by Wilwood. It's special powder coated by another place.
Old Jan 10, 2004 | 11:45 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Do we have a final GB price?
Old Jan 12, 2004 | 05:43 PM
N4Spd's Avatar
N4Spd
Default bump
bump, need total...
Old Jan 12, 2004 | 09:18 PM
Jeff@Evolution
GB will be up tomorrow. Prices will be up.
Old Jan 13, 2004 | 07:04 AM
azrael's Avatar
azrael
looking forward to it.
Old Jan 13, 2004 | 11:05 AM
Jeff@Evolution
We have just posted up the GB thread. We have 5 initial kits will be available at the new price of $1750 and will be ready to ship within 2-3 weeks. Here's the link.
https://my350z.com/forum/showthread....&postid=618187
Old Jan 13, 2004 | 11:40 AM
516_wrx's Avatar
516_wrx
JEFF,
when you guys send them off to the pwdercoater will the "WILWOOD" lettering be red as well or will they still be a different color like the black calipers?
thanks
ben
Old Jan 13, 2004 | 01:38 PM
Jeff@Evolution
Originally posted by 516_wrx
JEFF,
thanks
ben
The Wilwood letter will be silver just like the black caliper's letters.
Old Jan 13, 2004 | 01:58 PM
Mapleleaf's Avatar
Mapleleaf
Okay , I'm in Jeff, sending you the money give you the details on PM
Thanks
Old Jan 13, 2004 | 08:36 PM
  #38
Jeff@Evolution
Thanks
No problem. I'll give you a call as soon as I receive your payment. Let's get this thing rolling.
Jeff - Evolution
Old Jan 15, 2004 | 10:21 AM
  #39
Jeff@Evolution
Originally posted by ZxRage
I am interested, keep me posted....
Come on Raymond, these 6 pistons calipers would look so mean with the 14 inch rotors behind your New Wheels That would be the baddest combination.
Old Jan 15, 2004 | 12:41 PM
  #40
Mean Gene's Avatar
Mean Gene
Talking Me, Too!!
The list of participants that are already paid. For this GB's first shipment.
Updated 1/14/04
1. Mapleleaf - PAID
14" rotor kit. Red caliper. Cross drilled and slotted. Street pads
2. N4Spd - PAID
14" rotor kit. black caliper. slotted only. Street pads
3. Mean Gene - PAID
14" rotor kit. Black caliper. Cross drilled & slotted. Street pads.
