Whiteline 350Z Black Box StabilityContol ( turn of VDC)
Old Jun 21, 2012 | 09:06 AM
Wodiz's Avatar
Wodiz
Default Whiteline 350Z Black Box StabilityContol ( turn of VDC)
Hey guys !
I have owned a 350z now for 5 week and i like it alot, i got the novidem supercharger kit and am puting down 340whp.
I´m preparing it for drifting and i´vw noticed that the VDC kicks in when drifting although I turn of the esp ?
Are there no other way to turn the system completely of ?
Now to the Blackbox part.
Have someone actually used it ? Does it turn of the understeer problem when drifting ?
Is it worth the money ?
Or are there a moore effective and better way ?
Please be patient with my English !
/ I´m from Sweden !
Old Jun 21, 2012 | 04:41 PM
terrasmak's Avatar
Yaw sensor delete , do it .
Old Jun 21, 2012 | 05:06 PM
bimmertech's Avatar
bimmertech
this, or offset your steering angle sensor at least 20 degrees
Old Jun 21, 2012 | 11:01 PM
Wodiz's Avatar
Wodiz
i wrote this thread a little bit in a hurry.
So the best way is to install o switch on/off for the VDC in the cap besides the handbrake ( the way they do in the D.I.Y) ?
Old Jun 22, 2012 | 07:15 AM
PracticeDrifter's Avatar
PracticeDrifter
One of my wheel speed sensors went out randomly. It killed VDC and ABS. I left it that way of course.
Black box or racelogic are all just better kinds of VDC/traction control and are best for some sort of grip racing when you only want to slide a little.
If this is to be a drift car, I would just turn all the nannies off and learn to control it all with the throttle. Yaw sensor delete is the recommended method, I believe it leaves your ABS on.
The understeer problem is mostly fixed by a set of aftermarket swaybars - properly adjusted.
Old Jun 23, 2012 | 05:00 AM
ericjackson's Avatar
ericjackson
i popped my console up and just unplugged the unit. a lot cheaper than black box
Old Jun 23, 2012 | 08:53 AM
terrasmak's Avatar
I installed a switch to the ground as mentioned in the delete tread. If you unplug the unit , you can not reset abs. I like abs on the track and on the street.
aarrgghh
May 1, 2022 11:04 AM
350Shadow
Sep 22, 2015 08:30 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
CJs_Z33
Sep 18, 2015 12:06 PM
RyansZ33
Sep 15, 2015 05:54 AM
