help with bc racing coilover install
Old Jun 21, 2012 | 05:33 PM
zboy21's Avatar
zboy21
Default help with bc racing coilover install
ok so i just got my bc racing coilovers yesterday, they are the br type, oem style and im going to be doing the install myself. now i want to slam the car and i wanted some pointers and pic of how the install went. im really just want to no about the rear, what should i set my spring locks at and if io need to do anything to the rear shock. plaese note i do not no much about coilovers but im very handy when it comes to cars. thanks
Old Jun 21, 2012 | 05:44 PM
350zbehold's Avatar
350zbehold
the rear is easier then the front... whenever u get the coilover in your hand... the most basic things u want to do is to check for the top strut bolt , right in the middle.. tell a friend or somebody ( maybe your mom ) to hold the nut whille u're tighten it down as much as possible to prevent it from clunking noises that yoy may have later down the road. ( same goes with other three strut )
next up check for the spring and ring if it have any rock or anything in it. after that grease up the spring bucket and the spring ring where it goes on the spring bucket. with wd40 or anti rust...then u are all set...
Old Jun 21, 2012 | 08:41 PM
terrasmak's Avatar
Remove the upper spring collar in the rear on the spring adjuster , set the other full up , install , set shock short as possible to make sure it holds some preload on the spring .
