ExoticAir 4wheelcup suspension install, oem rear location, pics n details!
Old Jun 26, 2012 | 07:46 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you install your kits yet?
Originally Posted by stevehl
did you choose those specs for the swift springs? How is the ride?
I chose the specs on the springs. Full responsibility in my court.
Originally Posted by russ713
Wherever you have hoses running through exposed, metal holes in the body, make sure you line those holes with a grommet or a guard. Over a longer period of time, the metal will wear down into those hoses via vibration and create a headache for you later.
Agreed. Going to get some of that c shaped foam/rubber to protect the hose.
Old Jun 26, 2012 | 07:49 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Originally Posted by AmateuRN
Had cups before I decided to go bags... cups are def the way to go and several companies are now hopping on this to provide cheaper products.
I know the guy that bought your kit.
Old Jun 26, 2012 | 11:40 AM
BoomerZ33's Avatar
BoomerZ33
awesome. this looks like a nice alternative to the Roberuta.
Old Jun 26, 2012 | 05:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Originally Posted by SDGenius
not sure if you'll want shorter springs in the rear, even at ur current height it look's like the lower control arm is in danger of hitting the cups.
Negative ghost rider.
with the car on the ground:
Old Jun 26, 2012 | 06:05 PM
Kwame's Avatar
Kwame
Not yet. I have to admit that this thread has slightly resparked my interest in working on my car again. I' haven't touched my z in the last three months. It's time to dust it off as well as my tools and get back to wrenching.
Your modifications to the rear cups....can you go into any more detail as to what was done? Or is that top secret info?
Old Jun 26, 2012 | 06:50 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
bored to 50mm to fit over BC threaded adapter. Nothing to hide here! Was as simple as that.
If you look at the first two pics in the op you will see the holes in the top and the 2nd pic has the bc threaded adapter on top of the cup.
Old Jul 1, 2012 | 08:59 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Front down:
Front up:
With the rear up:
Old Jul 1, 2012 | 09:29 AM
Russ@Z1's Avatar
Russ@Z1
That's looks great dude.
I'm curious to hear your updates on handling and durability as you start to drive with this setup.
Old Jul 6, 2012 | 01:29 PM
b18ccivics's Avatar
b18ccivics
does this shorting the amount of suspension up travel?
Old Jul 6, 2012 | 02:24 PM
Chebosto's Avatar
Chebosto
always curious if these systems have a mechanical stop limit for reaching max height?
like... for the rear, the springs sit inside a cup, which itself is a piston.. so if you keep pumping air, the piston chamber will expand and the car goes up... so.. what's telling the rear to stop? or can you keep pumping air and the inner piston holding the spring in place can potentially shift out of the outter cup?
Old Jul 6, 2012 | 02:37 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
You lose about 1 inch for the cup width. Also depending on your springs they only have so much usable stroke.
There is a snap ring to hold the piston in place. When you install the setup you set sprin preloaded with the strut at it's extended length. So that will keep the spring in place since the cup can only extend the amount of strut that compresses when you lower the car up to the length of piston travel which is 3" in this case.
Spring rate and car weight will dictate how much the car compresses the strut under it's on static weight.
Old Jul 6, 2012 | 03:06 PM
Esser's Avatar
Esser
This is awesome, definitely on my to do list of mods.
Old Jul 6, 2012 | 03:14 PM
Waiz's Avatar
Waiz
Great thread OP, very well put together and thanks for all the pics.
Old Jul 6, 2012 | 03:26 PM
bmccann101's Avatar
bmccann101
not sure if i missed this in between the subscription replies going to my email, but someone had mentioned in one of the two threads on this that this set up was stupid for avoiding road bumps etc as theres no way to react fast enough etc...
I know theres ways home, ways to and from stores in my neighborhood, friends houses i visit that i have mentally mapped in my mind with a far different path that i would take in a car that had ground clearence.
Everyone has a driveway they avoid daily.. could have a better parking spot but the speed bumps are too big etc.. thats what this is for and is a great idea.. and somewhat necessary.
sorry to rehash if it had been covered in the meantime.. jsut thought it beared mention for future "searchers" as well.. if those exist anymore lol.
Old Jul 6, 2012 | 07:55 PM
Chebosto's Avatar
Chebosto
correct. i think this is just strictly for very low-speed entry/exit from driveways and getting onto/off ramps... def not anything at driving speeds.. and even if u did, IMHO the weight transfer may cause early wear of the piston seals...
Old Jul 6, 2012 | 08:11 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
This is amazing Cux, looks like I am spending even more money this winter.
Old Aug 19, 2012 | 04:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
fender is sitting on the tire.
Either the front needs to go lower or the rear a bit higher.
Old Nov 8, 2012 | 12:36 AM
  #38
Adon's Avatar
Adon
Linked here from driver thanks for info and good install notes here, gonna show this page to my buddies at the shop who'll be doing the install for me.
I don't know what experience you had with Phantom, but I gotta say I didn't have any problems whatsoever with communication from them, they literally were calling me like the day before heading out to SEMA, and got in touch with me soon as they got back, and I'm up here in Canada.
Also they're making my rear cups to sit in the spring bucket with the OEM style setup, I actually wanted the opposite of you as I don't like the OEM style setup on the BC RAcing coils, it's tricky to adjust height.
You got any videos of the car in action ?
airing up and down and whatnot ??
thanks
Old Nov 8, 2012 | 06:20 AM
  #39
Cux350z's Avatar
Cux350z
hatersgonnahate
thanks
My communication with Phantom, platinum VIP was brief. I would do business with either. They were much better than what I went through with Ravi from Umbrella. Ravi communicated it is just that he was kind of a jerk. His price is great though.
Pics of that cup when it is done. I will caution you though that the spring adjuster on the top may cause you some issues unless you are adjusting from the bottom. I liked having the cup on the spring adjuster since the mounting was already taken care of
I do not have a video. I actually am working on the controller for mine. It is going to be a windows to arduino microcontroller. Using bluetooth and custom code on both ends. It will monitor tank pressure, cup pressure and control the solenoids. Right now I have the oem seat heater buttons wired to control the up/down/compressor functions.
I really want another compressor since it takes forever to fill the 3 gallon tank.
The solenoids i purchased were not the best and leak some, gotta remedy that. It is in the npt fitting, not the quick connect.
I also mounted all the solenoids in the rear upper cubby behind the drivers seat. Nice and tucked away. I need to post more pics and updates.
Old Jun 13, 2014 | 07:05 AM
  #40
Cux350z's Avatar
Cux350z
hatersgonnahate
Bump. Added some pics of the install in drivers side rear cubby.
