350Z lowering help needed!
Old Jul 6, 2012 | 11:51 AM
Vsamimi1's Avatar
Vsamimi1
Default 350Z lowering help needed!
I realize that this subject has been posted many times before but it just doesnt seem like i can lower my car without any rubbing or suspension issues later on.
I want to drop my 07 Z lower than stock and have been researching for the right parts to do this mod. From reading all these posts i can tell that its going to be a pain in the rear end doing all the adjustments. How low can i go without ruining the suspension? I have 19" petrol throttle all the way around. 19X8 in front with 225 tires and 19X9.5 in the rear with 275s. Im not too worried about the front wheels it looks like the weels will clear the fenders with no problem. But in the rear it looks like the fender is going to sit directly on the tires once it drops. I dont want to have to roll fenders just because its 50 50 chance of ruining the paint. And on the other hand i dont want to have tire wear issue. I need some help to figure this out. I have seen Zs with a little negative camber barely clear the fender. I dont kow their tire wear is though.
I approciate any details you have about this thanks-
Old Jul 6, 2012 | 12:03 PM
KingBaby's Avatar
KingBaby
Hardest Setting
You don't want this and don't want that....don't do anything then!
Old Jul 6, 2012 | 12:32 PM
User 42426's Avatar
User 42426
so basically the only question you asked was how low can i go without ruining the suspension. I dont see why lowering your car will ruin the suspension.
Old Jul 6, 2012 | 12:35 PM
La_Fiebre's Avatar
La_Fiebre
Old Jul 6, 2012 | 12:38 PM
User 42426's Avatar
User 42426
but i will help since im bored at work.
First off, how low do you want to drop the z? Half inch? 1 inch? 2 inches?
Second, do you want to achieve the look with springs or coils?
Third, depending on how low you go, you will need: front/rear camber kit/toe arms, alignment, fender rolling.
What are the offsets of your wheels and tire profile? You can search several threads to see how your ride will look with your current wheel specs and the drop you want. If you do drop your ride lower than 1 inch, i believe you will need to roll your rear fenders. Fyi, its not really 5050 chance of messing up your paint if done correctly
Old Jul 6, 2012 | 12:46 PM
JCITY's Avatar
JCITY
It looks like you are worried about every detail.
Just leave it the way it is.
Just curious,what offsets are you running that your tires are as flush
as you are saying?Rolling your fenders should not "ruin" your paint.
Only the inner lip(you don't see it)is bended to allow for added clearance.
Old Jul 6, 2012 | 01:53 PM
realist alive's Avatar
realist alive
it sounds like your budget will not be large enough to do what you want. just leave the car alone.
Old Jul 6, 2012 | 01:57 PM
arsey51's Avatar
arsey51
Rollling your fenders will not ruin your fenders as long as you have a reputable person doing it. You can find guys here on the forum that do it.
Old Jul 7, 2012 | 11:13 AM
350ZZJoe's Avatar
350ZZJoe
I had my fenders rolled for $120 here in Canada at a reputable shop they took almost 3hrs applying heat and slowly rolling. They did an excellent job. Afterwards I cleaned up the gap and filled it with silicone so no water or dirt can sit up in there and rust it out.
As far as tire wear, suspension issues. You have to pay to play. Either go cheap now and pay for bushings, tires, struts in the future. Or pay big now and have everything dialed in properly.
Old Jul 7, 2012 | 11:21 AM
tylerxfire's Avatar
tylerxfire
sounds like you havent gathered much info. from ur "searching"
Old Jul 7, 2012 | 11:55 AM
Spence's Avatar
Spence
Sounds like 1/4 of this forum actually wants to help people and the other 3/4 are smart asses with too much of daddy's money....
Old Jul 7, 2012 | 11:58 AM
tylerxfire's Avatar
tylerxfire
or smartasses who work for their money...
Old Jul 7, 2012 | 12:02 PM
Spence's Avatar
Spence
Palm to face...
Old Jul 7, 2012 | 01:05 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Spencer please search
Old Jul 7, 2012 | 01:38 PM
Spence's Avatar
Spence
It's Spence and search for what?
Old Jul 7, 2012 | 03:01 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Sorry, Spender you made an ignorant comment! If you search, and read through the forum a tad longer you'd figure out how wrong you were.
Old Jul 7, 2012 | 04:42 PM
Spence's Avatar
Spence
Yes it's quite obvious that you're not a smartass....point proven.
Old Jul 7, 2012 | 04:49 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Old Jul 7, 2012 | 06:33 PM
Waiz's Avatar
Waiz
Read this thread OP
https://my350z.com/forum/brakes-and-...ion-101-a.html
3/4 of the forum already know how to search
1/4 don't bother searching and post first
Your 1 month of membership does not entitle you to make comments about site trends
James1990
Dec 16, 2015 08:57 PM
codek
Sep 27, 2015 03:21 PM
_koubie_
Sep 20, 2015 06:34 PM
350z_z33.
Sep 9, 2015 09:50 PM
