Problem with alignment
Old Jul 28, 2012 | 06:34 PM
jrose89's Avatar
jrose89
Question Problem with alignment
I've had my car since May and have yet to be able to get someone to align it.
When I took it the first time, they told me they couldn't align it and to get adjustable rear camber arms. I did this; they give -4,+4 extra degrees. They couldn't get the camber aligned passed +1 if the toe was in spec. If they put the camber in spec, it pushed the toe out.
So I then put SPC toe bolts on it which gives an extra -3,+3.
Still with all this, they can't get it aligned. At this point I'm not sure if they know what they're doing. I paid them so I wanted them to fix it.
I hope this all made sense..lol
Nothing looks bent under my car; I don't see any reason why it shouldn't be aligning. Anyone have any problems like this or know of anything it might be? Or does it sound like I should try somewhere else?
Old Jul 28, 2012 | 08:31 PM
Lee R's Avatar
Lee R
Post up the alignment specs they gave you so we know what you are dealing with.
Old Jul 28, 2012 | 08:48 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
Stock suspension or are you lowered? If lowered, on what?
Has anyone inspected your bushings?
Old Jul 29, 2012 | 06:54 AM
drivessidewayz's Avatar
drivessidewayz
What Sparkle said. Not enough information.
Old Jul 29, 2012 | 09:15 AM
jrose89's Avatar
jrose89
Lowered on gf210s. No one's checked the bushings.
Old Jul 29, 2012 | 01:22 PM
SparkleCityHop
Living in 350Z
Did you dremel out for the SPC toe bolts or just install them in the existing holes?
If not, try that.
If so, I would:
1) Double check my camber arm installation
2) Get the bushings checked
3) Post up alignment specs/printout so the alignment wizards on here can give you some advice
Also, are you running any of the following:
Wheel spacers
hubcentric adapters for aftermarket wheels
bent wheels
aftermarket wheels with different offsets
tires with different overall diameter than OEM
What were the "target alignment specs" that you/they were hoping for?
Old Aug 1, 2012 | 11:23 AM
jrose89's Avatar
jrose89
Rear
Old Aug 1, 2012 | 11:27 AM
jrose89's Avatar
jrose89
If not, try that.
If so, I would:
Wheel spacers
bent wheels
Bushings are ok
no spacers
got the hubcentric adapters
no bent wheels--has had three diff wheels on since may including oem 350z wheels
oem specs...just want my car aligned so it quits chewing my tires.
Old Aug 1, 2012 | 11:28 AM
jrose89's Avatar
jrose89
& we dremeled the holes for the toebolts.
Old Aug 1, 2012 | 11:53 AM
JasonZ-YA's Avatar
JasonZ-YA
get a new alignment shop.......or something else your not telling us is way off...i know the GF210 drop the car quite a bit, and if they have age, they sag even more...but still, they should be able to align to a matching LH and RH side at least...
-J
Old Aug 1, 2012 | 01:36 PM
Voboy's Avatar
Voboy
check the following:
1. the toe bolt dremeling on the right side.
2. the spring on the right side is installed the same as the left side, including the rubber spring mounts.
Old Aug 1, 2012 | 02:29 PM
djamps's Avatar
djamps
The left rear got some crazy toe going on. Has the car been in an accident?
Old Aug 1, 2012 | 03:11 PM
jrose89's Avatar
jrose89
after i talked to them today, they aren't even knowledgable enough to hold a conversation about what's wrong. they weren't able to align the car before the springs were even put on either. ive talked to nissan and the place the bolts are from and they both think the shop just sucks so im taking it somewhere else. they keep trying to say something is bent under my car, but there's literally nothing bent. everything measures up perfect. even a frame shop said if something was bent, that with the two parts ive put on, it can still be aligned. can't wait to get my $ back when the next shop CAN do it.
Old Aug 1, 2012 | 07:31 PM
djamps's Avatar
djamps
Let us know how it works out!
Uriyo_
Sep 8, 2021 08:46 AM
