Custom Coilover Setup?
Old Aug 10, 2012 | 06:46 PM
mr. sparco's Avatar
mr. sparco
Default Custom Coilover Setup?
Anyone have a custom coilover setup? Not the typical off the shelf type.
I've seen a few custom/track setups over the years with universal springs (ie Swift, Tanabe etc) on custom perches and adjustable Koni or Tokico shocks. Anyone on here have such a setup?
*Disclaimer: did not search on here as our search function kind of sucks, did try google and found some sparse info. I know some of you guys have Truechoice. Basically I'm just looking for a coilover sleeve setup without shocks. Skunk2 did have something in the market and Ground Controls never made it to production.
Old Aug 10, 2012 | 07:28 PM
03threefiftyz's Avatar
03threefiftyz
I'm not sure what you are asking, but I've had truchoice DA's in the past.
Old Aug 10, 2012 | 07:41 PM
mr. sparco's Avatar
mr. sparco
Are there any coilover sleeve/springs that will fit Tokico adjustable shocks?
Old Aug 11, 2012 | 03:04 PM
03threefiftyz
Do the tokico's use a snap ring like koni? What is the diameter of the shock body?
Old Aug 12, 2012 | 09:51 AM
mr. sparco's Avatar
mr. sparco
The fronts have a spring cup welded on but that can be cut off and ground down like Konis I believe. Shock body should have a 2" diameter but I will measure again to be certain.
Old Aug 12, 2012 | 10:16 AM
03threefiftyz
If it is a 50mm body, and you can get the koni style sleeve to sit on the perch....you can use the ones from truechoice/koni most likely.
Old Aug 12, 2012 | 01:46 PM
mr. sparco's Avatar
mr. sparco
Thanks for the help 03, I'm piecing it together and ordering. What spring rate for the front and rears on the Dspec shocks? I rarely track, last time was 3 years ago, just need it for daily use and still be able to adjust height and comfort.
Old Aug 12, 2012 | 02:08 PM
03threefiftyz
I don't know anything about D-specs...
The sleeves will only work on the front with an OTS shock. You'll have to piece together rear spring perches for the stock toe buckets. You can piece them together from stance, megan, etc. Truechoice also makes them, but they are $400-$450 for just the perches.
Old Sep 19, 2012 | 09:09 PM
ModBargains's Avatar
ModBargains
Vendor - Former Vendor
you should look into cks coilovers. You can build to your own spec and they also have couple set up available for the Z. Let me know if you have any more questions
Old Sep 19, 2012 | 09:43 PM
mr. sparco's Avatar
mr. sparco
I gave up on it, but thanks for the advice, stayed with the Tokico Dspec/springs incl kit.
350Z_Al
Oct 29, 2020 07:44 PM
