KW suspension no bueno!!
Old Jun 15, 2013 | 10:44 AM
  #41
stuartc323's Avatar
stuartc323
sounds like babys first set of coilovers.
You didnt adjust the preload right and the damper took all the weight from the car. You overloaded it even though its a KW damper you either was riding close on the bumpstop or had the car sitting at the dampers lowest point of travel. All that constant weight at the lowest point of travel can cause the dampers to leak.
Get your KWs rebuilt, than after you get them rebuilt, search on how to measure damper travel and how to preload the springs according to the damper travel, and you wont have to do this again. You have some of the best coilovers made for this car.
Old Jun 15, 2013 | 10:58 AM
  #42
XM 1's Avatar
just wtf how could you preload that suspension? and even if so what has that to do with the car being to low?
Old Jun 15, 2013 | 11:01 AM
  #43
stuartc323's Avatar
stuartc323
thats what the threaded perches are for on the coilover, you adjust preload to the springs to adjust height, the damper doesnt affect ride height at all, every coilover has this ability, thats why your able to corner balance cars with threaded perches.
Old Jun 16, 2013 | 02:24 AM
  #44
XM 1's Avatar
oooh you mean that...sorry i´m from germany so sometimes not really sure about the translation did this! and still it´s too low.
Old Jun 16, 2013 | 11:46 AM
  #45
kyle22's Avatar
kyle22
OP, take a picture of the rear suspension for us. I think you didn't do it right or you need to rebuild them.
Also, I would read this https://my350z.com/forum/brakes-and-...ion-101-a.html
specifically post #17 and #18
Old Jun 16, 2013 | 09:52 PM
  #46
XM 1's Avatar
i'm pretty sure it's installed correctly i'm not a noob at installing suspensions....and never had any problems with other cars like this
post 17 sounds strange???
OEM Style rear:
Adjust at the spring bucket location and at shock location like true coilovers style.
there's no way you could adjust at the shock location???
Old Jun 16, 2013 | 11:24 PM
  #47
XM 1's Avatar
since there's too much confusion going on here (IMO) i'll just post the manual which KW gives away with the suspension kit....
http://docs.kwsuspension.de/eah68685002.pdf
take a look at page 3 for the info
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
