Identify this piece on HKS Hipermax III Sport coilovers
Old Aug 25, 2012 | 05:16 PM
nismofreak1208's Avatar
nismofreak1208
Default Identify this piece on HKS Hipermax III Sport coilovers
So today when i was leaving a gas station on a very low to moderate angle driveway. The rear passenger corner suddenly emitted a loud "POP" and as such I pulled over to see if i blew a tire. Come to find out when i compared both rear coilovers, the "gold" round **** piece is what snapped off leaving what seems to be a small metal guide that it used to sit on. I'm trying to identify what this piece is, what it does, and will i be able to repair it without having to buy a WHOLE new set of coilovers since HKS will not send replacement coilovers. Thanks!
Uploaded with ImageShack.us
Attached Thumbnails Identify this piece on HKS Hipermax III Sport coilovers-hks.jpg
Old Aug 25, 2012 | 05:24 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
looks like the dampening setting ****
Old Aug 25, 2012 | 05:43 PM
Glex25's Avatar
Glex25
That's what I thought too but I did some research and I don't see any type of adjustment for dampening or rebound for this setup
Old Aug 25, 2012 | 06:09 PM
KingBaby's Avatar
KingBaby
Hardest Setting
Ouchy Mr. Wallet isn't gonna like this!
I agree on the damper **** or pressure gauge of some sort.
I just took off my Stance coils and also have 3 different complete stock setups if you need a temp setup!
Good luck
Old Aug 25, 2012 | 07:04 PM
alfhasg35's Avatar
alfhasg35
It's the dampening **** Fosho...
Old Aug 25, 2012 | 07:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
I thought so at first as posted above but on second look it appears to be at the wend of the shaft. Unless the shaft is hollow that **** is in the wrong spot to be changing a valve opening.
Old Aug 25, 2012 | 07:10 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Maybe it connects the fork to the shaft to prevent rotation.
Old Aug 26, 2012 | 04:48 AM
wawazat8402's Avatar
wawazat8402
Unless its an inverted setup.
Old Aug 26, 2012 | 06:43 AM
alfhasg35's Avatar
alfhasg35
I have these. Dampening **** Fosho..
Old Aug 26, 2012 | 07:40 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Yeah now that I re-re-re think about it (glex's post through me for a loop) it has to be the dampening adjuster. MY bc's have them on the shaft as well but since this is an inverted setup the shaft connects at the fork vs the top like most others.
Old Aug 26, 2012 | 03:40 PM
Glex25's Avatar
Glex25
Look up the specs for this setup and let me know if it says it has any type of adjustment apart from height.
All vendors seem to have the same description and none say it.
Let the owner chip in and say if it does have those adjustments
First thing that came out of my mouth was rebound/dampening adjustment **** until I did a look up
Old Aug 26, 2012 | 03:45 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
http://intensepower.com/hkshiiiiconi.html
30 way adjustable dampening
Old Aug 26, 2012 | 07:52 PM
Glex25's Avatar
Glex25
That link is showing the regular meanwhile he stated on the title of the thread it's the sport series
I'm going by these sites
http://www.conceptzperformance.com/c...466.249.68.229
http://www.jscspeed.com/catalog/Niss...initi_G35.html
http://www.evasivemotorsports.com/mm...HIPERMAX-SPORT
http://z1auto.com/prodmore.asp?model...ng&prodid=3043
http://www.hks-power.co.jp/usa/produ...3437_more.html
Old Aug 27, 2012 | 02:51 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
https://my350z.com/forum/8711108-post40.html
https://my350z.com/forum/8841676-post52.html
it is 100% the dampening adjuster ****.
Old Aug 28, 2012 | 12:40 AM
nismofreak1208
its dampening......
Old Aug 28, 2012 | 03:51 AM
Glex25's Avatar
Glex25
Originally Posted by nismofreak1208
its dampening......
was it removable or do you have to order a whole cartridge just because of that?
That was my first thought also but why doesn't it stated on the description on any site including the manufacture.
Old Aug 29, 2012 | 04:31 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Definitely a damping ****!
Old Aug 29, 2012 | 05:06 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
It would cost more in Jersey..........it is a taxable asset.
Old Sep 26, 2012 | 08:55 PM
zhi33's Avatar
zhi33
hey guys. just searched these and I am kind of questioning how to adjust it? since i am now in a town which are suck roads, my 350z just keep jumping all time long. my original setup for the rear damping are extremely hard. but i don't know how to adjust them. can you guys help me out? and normally what are your setting for regular driving?
Old Sep 27, 2012 | 12:03 AM
KingBaby's Avatar
KingBaby
Hardest Setting
If you have the coils pictured above. The **** highlighted is for the dampening. Which in turns stiffen/soften ride quality a bit. The correct way would be to start over on your preloads for the spring since your road conditions have changed dramatically.
sales@czp
Sep 23, 2019 03:30 PM
