can rear camber be adjusted without camber kit?
Old Dec 28, 2012 | 08:11 PM
Marcodiaz93's Avatar
Marcodiaz93
Default can rear camber be adjusted without camber kit?
i lowered my car with eibach pro kit springs and also put 25mm spacer in the back and 20mm in the back. i waited about 3 weeks for everything to settle before i did an alignment. well i went to get an alignment today and the guy said that the front and rear toe and camber were off. he said he could adjust the rear camber but not the front. i asked how he would adjust the rear without a camber kit and he was kinda clueless. well anyway i told him to just adjust the front and rear toe. the front camber is off -1.5 on left and -1.9 on right. should i be worried about front? and also the rear is -2.7 on left and -3.2 on rear. i dont understand how he will adjust without camber kit?? well if i get rear camber kit and adjust back to spec, will my tires rub on fender since i have 25mm spacers and lowering springs?
Old Dec 28, 2012 | 09:00 PM
harman850t5's Avatar
harman850t5
The factory rear camber arms have eccentrics. But I don't know if they'll have enough adjustment to bring back to spec. You should be alright with the front camber.
Can't help you with the spacer question though
Old Dec 29, 2012 | 12:00 AM
350Zdj's Avatar
350Zdj
The rear camber can be adjusted through the OEM eccentric bolts. I was able to have mine adjusted from -2.7 to -2.0 at the rear.
The front camber is OK
More info here
https://my350z.com/forum/brakes-and-...ion-101-a.html
Old Dec 29, 2012 | 09:40 AM
beezee's Avatar
beezee
That is a sign you should take it to someone that has a clue.
Old Dec 29, 2012 | 03:26 PM
Marcodiaz93
ok i wonder if i should get a camber kit or just align it to the 2.0 in the rear since idk if i put it to spec if it will rub or not.
Old Dec 29, 2012 | 05:52 PM
beezee's Avatar
beezee
Camber kits are not expensive. Get a set so you get more control over how close you can get it in spec. SPC is a popular choice here
Old Dec 30, 2012 | 02:30 AM
Marcodiaz93
i dont drift, track, or do anything crazy with my car. its my daily driver, i just want to avoid getting new tires every few months lol. can i just get a godspeed camber set for rear and fronts and be ok?
Old Dec 30, 2012 | 07:51 AM
terrasmak's Avatar
I wouldnt buy GodSpeed anything, there are much better "cheap" parts out there. SPC, kinetix or Megan, you will be fine.
http://www.kinetixracing.com/nissan350z03-06-3.aspx
www.nissanraceshop.com
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
