Tanabe gf210's question.
Old Mar 1, 2013 | 04:18 PM
Gray8188's Avatar
Gray8188
Default Tanabe gf210's question.
Thinking about getting the gf210's just want to make sure I don't have any rubbing issues. I'm running Xxr 527's 18x9.75 all around with a +20 offset with 275/40/18 out back and a 255/40/18 up front. Or if anyone has any pics of this setup. I haven't been able to find any.
Old Mar 1, 2013 | 05:54 PM
terrasmak's Avatar
You will probably need a minor roll.
Old Mar 1, 2013 | 06:13 PM
Gray8188's Avatar
Gray8188
Rear fenders? I was thinking I would. Will I need to do anything with the front?
Old Mar 1, 2013 | 07:14 PM
NoQuestionZ's Avatar
NoQuestionZ
There is ONE screw on the front fenders that holds part of your wheel well splash guard in place. If you don't remove this and your tire hits it, it could cause a bump in your fender where the screw was pushed into the metal. I have 19x9.5/10.5 +17/18 w/ 255/35 fronts and 285/35 rears. Rent a fender roller for the rear, and remove the screw for the fronts.
Old Mar 1, 2013 | 08:06 PM
terrasmak's Avatar
With the offset the OP has, he will probably be good. Then there is also the remove the screw , cut the screw in half and install the screw again trick. you can also pull the front fenders easily. I did wetdreamzzz front fender pull at the track. Took me 2 minutes.
Old Mar 1, 2013 | 09:26 PM
CleanFairladyZ's Avatar
CleanFairladyZ
^this is the first time i'm hearing of this screw problem lol. tomorrow is actually the big day im lowering with yellows and eibach prokit. I'm on stockies though, so should it matter at all?
Old Mar 2, 2013 | 05:49 AM
Gray8188's Avatar
Gray8188
Thanks guys I appreciate all the help. Hopefully ill have it done in the next couple weeks.
Old Mar 2, 2013 | 06:05 AM
terrasmak's Avatar
Nothing to worry about unless your running 25mm spacers or more on your stock wheels.
Old Mar 2, 2013 | 08:39 AM
CleanFairladyZ
^thanks terrasmak
Ace2347
Sep 22, 2015 03:12 AM
_koubie_
Sep 20, 2015 06:34 PM
