Lowering on Ebiach SportLine springs on stock rims/stock suspension
Old Mar 3, 2013 | 12:47 PM
Colourdeaf's Avatar
Colourdeaf
Default Lowering on Ebiach SportLine springs on stock rims/stock suspension
Hey guys, always been a lover of this forum and its my turn to for answers.
My 2003 Nissan 350z keeps asking me to lower her on Sportline ebiach lowering springs with feature a end result of 1.7" to 2.3" drop.
My question : if I only upgrade my suspension by lowering springs am I going to wear my tires down extremely fast
With stock shocks and struts am I going to cause them to fail because a lot of people say its okay to use stock shocks and struts but they will last a shorter life time but not severe.
Camber kits ? Some say yes. Some say no
Will I need to roll my fenders?
I have stock 03 rims with Yokohama sport low profile tires 245/40r/18 front and 275/35r/18 rears
Car is stock.
Old Mar 3, 2013 | 02:38 PM
logan09's Avatar
logan09
You will need front upper control arms and rear camber arms at a minimum.
Old Mar 3, 2013 | 02:54 PM
Colourdeaf's Avatar
Colourdeaf
If I stay with stock upper control arms, what will happen ?
Camber arms for sure I believe though, I'll get those skittle bit down the line with a allighment
Old Mar 3, 2013 | 04:03 PM
logan09's Avatar
logan09
Stock upper control arms do not allow for camber adjustment that you will need, just premature tire wear will happen
Old Mar 3, 2013 | 06:49 PM
TimsZee's Avatar
TimsZee
Dropping that much, yes front a rear camber arms. You should pick up a set of toe bolts as well. You shouldn't need to roll your fenders.. I have 285 with a 22 offset and they were rubbing oh so lightly.
Old Mar 3, 2013 | 08:12 PM
Colourdeaf's Avatar
Colourdeaf
Thanks for your guys input and recommendations
I'm going to throw up pictures of before/after and a video so stay tuned
I'll be adding the upper arms and rear camber kit/toe bolt kit soon after i upgrade my springs so it will be upgraded springs for a month then i'll be upgrading
