New coilovers? help!
Old Mar 18, 2013 | 04:05 AM
JaredHeckman's Avatar
JaredHeckman
Angry New coilovers? help!
okay whats up guys , i recently have tein basics on my Z
and it doesnt sit low enough for me. so i was looking at the
stance coilovers. would this be a downgrade? do stance go really low?
cause i know tein is a really good brand.. just not sure what
to do ,, recomendations well appreciated.. thanks
here is a pic of my car as you can see the wheel gap
in the rear ...
Old Mar 18, 2013 | 05:00 AM
terrasmak's Avatar
Since the OEM spring mount is used , you can do the spring mount mod. It also looks like you may be running civic sized tires or front tires mounted in the rear of your car, a tire swap to proper tires will help with the gap.
Old Mar 18, 2013 | 06:27 AM
Z_on_TE37's's Avatar
Z_on_TE37's
Lol, civic tires. Personally I don't understand why those coilovers keep you so high off the ground, at least get to tire level if you want to be "hellaflush" with your stretched tires. Stance are good coilovers, I've never heard any complaints about them. If you won't be happy with the way it looks until you tuck tire, then get the new coilovers.
Old Mar 18, 2013 | 07:42 AM
JaredHeckman
lol civic tires , there 35 sidewalls , but thanks and yea im looking for a hellaflush look , or a tire tucking look at least , pretty much just no wheel gap , but i guess im not gonna get them out of these coils. thanks though
Old Mar 18, 2013 | 08:41 AM
Z_on_TE37's
Yeah. My fortune autos got me to tire level and that's where I wanted to be. I have a friend who has stance and they seem really nice. If you don't plan on tracking the car, just get the bc coils, they are cheaper if ur worried about $, and they are basically the same as stance, just lower quality.
Old Mar 18, 2013 | 09:19 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Spring mount mod + remove the collars.
Old Mar 18, 2013 | 09:23 AM
Scrildo's Avatar
Scrildo
Wow that sucks for you man sorry. Thats why i always do a lot of reading and researching on the forums before i buy something to make sure its what i need/want.
Old Mar 18, 2013 | 11:40 AM
terrasmak's Avatar
As you reduce width you need to go up in sidewall height. You probably need 40 series tires
Last edited by terrasmak; Mar 18, 2013 at 12:49 PM. Reason: Wrong person got quoted
Old Mar 18, 2013 | 12:11 PM
Z_on_TE37's
Why did you direct this to me ?
Old Mar 18, 2013 | 10:48 PM
stascom's Avatar
stascom
Why would the quality of coilovers matter for a slammed car?
Old Mar 19, 2013 | 12:51 AM
KingBaby's Avatar
KingBaby
Hardest Setting
Race land
Old Mar 19, 2013 | 08:26 AM
User 42426's Avatar
User 42426
either do the shorter spring mount mod and remove collars. If thats now low enough, choose among: bc coils, d2 coils, ksport, megan, stance, top speed. All budget coils that can get what you want. I am currently running d2 and they can put your car to the ground, and im pleased with the ride.
Old Mar 19, 2013 | 10:42 AM
JaredHeckman
how do i go about the spring mod? or whatever. what do you do? nver heard of that before
Old Mar 19, 2013 | 10:44 AM
AdvanZ33's Avatar
AdvanZ33
https://my350z.com/forum/brakes-and-...mount-mod.html
I think there was a set that was already cut for sale in the Marketplace no too long ago.
Old Mar 19, 2013 | 04:38 PM
QuintonC's Avatar
QuintonC
D2's go pretty low as well. That's what I'm running, ride about as well as OEM if not the same imo. I'm not all that low at the moment, but when I had the coils slammed, dude.. I was pretty dang low. They're true type and wouldn't require spring mount mod, etc.
Old Mar 20, 2013 | 02:43 AM
nismo4life11's Avatar
nismo4life11
Remove the rear collar and do the spring mount mod it will get you close to where you want to be you'll need to roll your fenders though and you'll probably also need to throw some negative camber in the rear to.
Old Mar 20, 2013 | 07:49 AM
driftsucky's Avatar
driftsucky
Hey. D2 showing up. Awesome. I'm also on those. Love'em. That said, what is your goal with this car? Like Terrasmack said, you can run a taller tire and clear up the wheel gap and based on where your wheels sit now, you'd probably also be "hellaflush".
If you want to go lower, Stevehl has listed coils that will slam you. I can tell you that as the low goes, Stance and D2 are the lowest. You can not max out those in the front and still drive. They will LITERALLY have your frame on the ground. Of those 2, Stance are more expensive. IMO, those are the only 2 worth mentioning if you want low cuz Stance is the most expensive and other than D2, nothing else will get you as low.
Now, nobody has mentioned it but I'm sure some of thought it, what you may not know about slamming a car is that is disrupts the cars geometry. So, once you pass a certain point, performance need not be a concern. Since you're looking to be hella flush, you should also be informed that as you get lower and lower, your wheels will begin to camber inward (i.e. negative camber) moving the top of your wheel further away from your wheel well edge. That means that while you may be low, you may still encounter the gap issue. It just turns from an issue of width instead of height.
To cure such an issue, you may, then, need to acquire not only spacers, but you may also need camber arms to help ensure that your tires don't wear unevenly. The camber arms will allow you to adjust the camber (as their name suggest) so that you can stay within spec.
So, if you're trying to achieve the "hellaflush" look, the cheapiest/easiest way is to do as terrasmack said and get taller tires. To be slammed AND hellaflush is an entirely different beast.
Old Mar 20, 2013 | 10:03 AM
JM Auto Racing's Avatar
JM Auto Racing
MY350Z.COM Sponsor
If I may chime in a bit, I would say go with the D2 racing coilovers if you are looking to go low. They are a true coil over rear and can drop really low.
Car looks nice by the way.
__________________
Email:sales@jmautoracing.com
AIM: jmautoracing@gmail.com
www.jmautosports.com
1-855-998-8726
Stevo Z
Oct 3, 2015 09:14 PM
