Rear Brake Caliper Question
Old Mar 25, 2013 | 08:00 AM
4DRVIPER's Avatar
4DRVIPER
Default Rear Brake Caliper Question
Can anyone tell me if the rear stock calipers from a G37/370Z fit a 2008 350Z?
In looking at the 2, it appears to be the same, however it may be like the 2003-05 caliper being a little different from the 2006+ caliper which used a slightly larger rotor. Any guidance is much appreciated. Thank you.
Old Mar 25, 2013 | 09:29 AM
terrasmak's Avatar
Don't know , but i know the 03 to 08 rear calipers are all the same. You can look up the rebuild kits for the 370 and see if they are the same as the 350z versions
Old Mar 25, 2013 | 09:31 AM
4DRVIPER's Avatar
4DRVIPER
I thought the 2006-2008 calipers used a slightly larger rotor....
Old Mar 25, 2013 | 11:43 AM
TuckerE36's Avatar
TuckerE36
I'm pretty sure they do.
Old Mar 25, 2013 | 12:10 PM
secwind's Avatar
secwind
The calipers will bolt right up; not sure if the rotors are the same sizes though.
Old Mar 25, 2013 | 12:20 PM
terrasmak's Avatar
Same caliper, different mounting bracket that allows a bigger rotor.
JjL
East Canada
Jun 12, 2019 03:04 AM
seagrasser
Oct 11, 2015 03:27 PM
350Shadow
Sep 22, 2015 08:30 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
