oversized wheels rubbing-coilover options
Old Apr 9, 2013 | 09:51 AM
drabes350's Avatar
drabes350
Default oversized wheels rubbing- options?
SOLVED
so i bought my 06 350z in the fall and now its time to put it on the road. the problem is the rear offset isnt really right and they stick out to far/rub fender everywhere. Rears are the xxr 20x11 526, ET 13 all-round, Tires are 285/30/20.
I already plan on rolling the fenders but i think it needs a little more than that
iv been researching coilover options but i need some help deciding and maybe some of you guys running aggressive rear set ups and shoot me in the right direction. im not looking for very high end, dont plan on racing or drifting the car, just wanna mainly fix my problem..keep a clean looking stance, and dont mind the added performance & adjustability you get with coilovers.
what rear rates do you guys recommend? True coilover vs OEM rear style? kits with camber adjustment?
i was looking at the BC BR kit which is a oem style and camber adjustment the rears..the spring rates are only 10/8k (EDIT: you can oarder any rates you want)
heres some pics to show ya what im working with
Attached Thumbnails oversized wheels rubbing-coilover options-2.jpg   oversized wheels rubbing-coilover options-compressed-.jpg
Last edited by drabes350; Oct 6, 2017 at 09:15 AM. Reason: Solved xxr 526 20x9 20x11 +13
Old Apr 9, 2013 | 09:55 AM
Waiz's Avatar
Waiz
Roll your fenders and add some negative rear camber, no coilovers are needed
Old Apr 9, 2013 | 10:18 AM
drabes350's Avatar
drabes350
can this be adjusted at stock? or do i need to get some aftermarket camber componets?
Old Apr 9, 2013 | 11:09 AM
07maximan's Avatar
07maximan
This is exactly the kind of info I was looking for earlier...
I wish this had been posted yesterday. I ordered some 285/35/19's for my 11" rear wheels and I dont really want to have to deal with this. For the to tuck inside the fender it looks like you would need some serious negative camber. Then you run into the problem of tire wear...oh boy.
Old Apr 9, 2013 | 11:34 AM
drabes350's Avatar
drabes350
thats exactly what i dont want!...so i was hoping with a combination of stiffer coilovers and a little bit of camber adjustment could get me there
where to start?
Old Apr 9, 2013 | 11:52 AM
terrasmak's Avatar
Just roll the fender, you will clear no problem. No extra camber is needed.
Old Apr 9, 2013 | 12:26 PM
07maximan's Avatar
07maximan
Really? This is where I seem to have an issue. Youre saying that by just rolling the fender it wont rub? It looks like its sticking out a 1/2" from the fender...
Old Apr 9, 2013 | 12:30 PM
KingBaby's Avatar
KingBaby
Hardest Setting
+1
Why would coilovers be an option? Are you gonna raise the car up higher
roll and a slighty pull
Old Apr 9, 2013 | 12:45 PM
drabes350's Avatar
drabes350
Originally Posted by KingBaby
+1
to gain a stiffer suspension so the car doesnt sink so far?
Old Apr 9, 2013 | 12:50 PM
drabes350's Avatar
drabes350
there more like a 1" 1/2 from the fender lol
Old Apr 9, 2013 | 12:53 PM
Waiz's Avatar
Waiz
where to start?
You have a completely different setup than this person
You both need to roll your fenders, worst case add camber later (if needed at all)
Old Apr 9, 2013 | 12:55 PM
KingBaby's Avatar
KingBaby
Hardest Setting
you can buy a stiffer spring!
07maximan's Avatar
07maximan
Ok. Since Im new to the whole wheel and tire thing for the Z Ill take your word for it. Thanks
Old Apr 9, 2013 | 01:21 PM
terrasmak's Avatar
As the suspension compresses , you gain camber. Read about it, we have a lot of camber gain do to the unequal length control arms. Springs do not keep you from rubbing, they just make things stiffer. With your suspension set up on stiffer springs you should still have the same amount of up travel, if you rub with soft springs , you will rub wiuth stiff springs, but it will take a little harder of a hit before they touch.
As Waizzz mentioned, roll the fenders, if you still rub, add a slight amount of camber till the rub goes away.
On cars that are really freaking close, i like to set the camber with the spring removed. I set it to where it will not rub. Then install the springs and bring the car up to ride height and set the toe.
Old Apr 9, 2013 | 02:34 PM
03threefiftyz's Avatar
03threefiftyz
On bumps under heavy load I have had contact between the wheel and shock body with an 18x12 +19 w/ -2.5 of camber...2.5mm spacer solved the problem.
Old Apr 9, 2013 | 05:13 PM
rcdash's Avatar
rcdash
Another option is of course... just buying wheels with the right offset, say like +25 to +30 for an 11 inch wheel!
EDIT: Of course, rolling the fenders doesn't hurt, but just trying to tuck the tops of the tires into the wheel wells accomplishes little if you're way out there (looking back at your small pics again, doesn't look too bad I guess). It still looks suboptimal and you will likely end up with more negative camber than is necessary or useful.
Old Apr 9, 2013 | 05:49 PM
drabes350's Avatar
drabes350
yeah diff wheels is always an option, but if thats kinda last case scenario for me
ik the pics a little small but
its like a 1 1/4 from fender to outside of sidewall, and 1/2" to the middle of the thread line where it currently rubs. i got about 2" of gap too -_-
so your sayin i would need alottt of camber to tuck something like that?
do those measurements make a difference to any one?lol
Attached Thumbnails oversized wheels rubbing-coilover options-2big.jpg   oversized wheels rubbing-coilover options-compressed-.jpg
Old Apr 10, 2013 | 10:43 AM
drabes350's Avatar
drabes350
any body else have input? 285/30/20 +13 OFF...really clear with just rolled fenders??
Old Jun 28, 2013 | 07:26 PM
slmdchvy05's Avatar
slmdchvy05
I have no issues, I didn't have to roll my fenders when I lowered mine about 2" to 2.5" in the rear running 285/35/19 on 370z sport wheels "19x10 30mm offset" and the alignment is within specs. I don't think coilovers or stiffer springs will solve your problem because I am running Stance GR+pro true coilovers that have the helper springs, and I upgraded to the Swift springs with a stiffer spring rate and it still has a decent amount of travel. I hate to say it but if I were you I would just bite the bullet and get some wheels with a different offset, you will not regret it due to you will have to roll and stretch your fenders and prob have to do some neg camber and wear out your tires.
Here is a pic of mine
Old Jun 29, 2013 | 06:22 AM
driftsucky's Avatar
driftsucky
Options:
1) Roll Fenders
2) Change Tires (275 or 265...which will be a stretch...not optimal but an option)
3) change wheels.
Looking at that, I'd assume you'd need somewhere in the -5 to -7 camber to clear that fender with no further adjustments. And, quite honestly, I'm not really sure if you have the stomach for that. A lot of people get all squirely past -3.
I still think your BEST option is to just pull the fender. A roll will do you no good because the tire sticks out past the fender. You'll have to do a slight pull to make it work. But, a heat gun, a roller, and 2 hours will get'r'dun. If you're in a really tight jam, you can even use a heat gun and rubber mallet. It's a bit riskier, but if you take your time, you can achieve your desired result without getting gremlin fenders.
