Square camber F&R for aggressive street driving
Old May 14, 2013 | 06:49 PM
grug1's Avatar
grug1
Default Square camber F&R for aggressive street driving
Hi all
Currently trying to decide baseline camber and toe settings front and rear for agressive street/ road duties in my 06 Touring.
By way of background, My Subaru WRX dual duty track/ street car has successfully ran 2.2F and 1.8 R with zero toe all around for years with nice even tire wear across all 4 tire faces. Given this is my "alignment sweet spot" in an all wheel drive WRX running same offset wheel/ tire size on each corner, I'm not convinced these alignment figures will translate to my 350z.
For those in the know, how does a 350z baseline alignment running 1.8 deg neg all around with 1mm toe in sound?
Car as I've said is a 06 Touring and will run 19x9+22, 19x10+22 with 245/40 285/35 riding on Swift Spec R 1.2"& 1" drop respectively with Bilstein R8 dampers.
Old May 14, 2013 | 07:18 PM
terrasmak's Avatar
Aggressive street , your prior specs from your other car will work as a great starting point. Your tire selection on the other hand , I highly suggest looking at 265/35 for a front, at minimum a 255/35 front to go with the 285 rear.
Old May 14, 2013 | 10:27 PM
grug1's Avatar
grug1
Thanks for the advice, really appreciate it.
Old May 15, 2013 | 12:37 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
Please post your impressions.
Old May 15, 2013 | 03:31 PM
grug1's Avatar
grug1
Will do
Also, can anyone explain why the factory static front camber settings are so weak?
OEM static front camber settings lifted from 'Service Data and Specifications'
Minimum. -1.33
Normal. -0.58
Maximum. 0.17
Have the Nissan engineers designed the front end to dramatically increase dynamic negative camber? If this is the case I'd definitely like to know as it would be a huge win win for straight line stability and mid corner mechanical grip.
Old May 16, 2013 | 06:20 AM
Chi-TownWarrior
I believe you answered your own question.
Don't quote me on that...
Obadabot
Jun 18, 2023 11:31 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
