StopTech ST40 BBK
Old Jun 22, 2013 | 10:41 AM
1000gixxer's Avatar
1000gixxer
Default StopTech ST40 BBK
Good Day
Need Info
The caliper mounting bracket bolts , does the washer go against the head of the bolt or is it a spacer ?
Install notes make no mention of washer location or caliper centering on rotor issue .
Thanks in advance
Gixxer
Old Jun 23, 2013 | 09:01 PM
ronn1's Avatar
ronn1
Originally Posted by 1000gixxer
Good Day
Need Info
Thanks in advance
Gixxer
This shows bracket and washers
Here is the manual..page 16 says washers go under the nuts>>>
http://www.stoptech.com/docs/install...98-646-1450-02
Install the jet nuts onto each stud, with one
12mm washer under each nut. Tighten the jet
nuts to 40 lb-ft of torque, using a 1/2” socket.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
