Pls help!!coilovers
Old Sep 27, 2013 | 06:48 PM
Ryndaco's Avatar
Ryndaco
Default Pls help!!coilovers
I am new to this , but please can someone till me if what kind of coilovers that has highr spring rate or like 12k-16k or 14k-18k . I knew pbm but the rear r only 8k Thanks in advance.
Old Sep 27, 2013 | 07:01 PM
terrasmak's Avatar
Moton , they can handle it no problem.
With high end coilovers, you supply the springs that you want.
Why do you need springs that stiff? Major aero parts, wide slicks?
Old Sep 27, 2013 | 08:09 PM
Jcrisp's Avatar
Jcrisp
Need to know what you're going to be using your car for and how smooth of a ride you want
Old Sep 27, 2013 | 08:18 PM
winchman's Avatar
winchman
Do you realize that the mounting points and bushings for the shock absorbers were designed for the intermittent loads associated with the shock absorbers? The coilovers put the weight of the car on those parts all the time with intermittently higher loads when the springs are compressed.
Stiffer springs make the intermittent loads even higher. That just seems like a really bad idea.
Old Sep 28, 2013 | 12:08 AM
HAWAI'I's Avatar
HAWAI'I
screw the coilovers! Weld your shocks!
Old Sep 28, 2013 | 12:47 AM
Emski's Avatar
Emski
Don't forget to weld your diff, door, and steering rack!
Old Sep 28, 2013 | 04:40 AM
Ryndaco's Avatar
Ryndaco
Just a nice stance and maybe track every month
Old Sep 28, 2013 | 09:34 AM
Jbakes727's Avatar
Jbakes727
I went with 12/10. I think it's perfect for a daily driver. Rides pretty good and it's not too stiff.
Old Sep 28, 2013 | 10:52 AM
terrasmak's Avatar
Mine is a dedicated track car, and runs 13k front and 6k rear. So, since your a local Vegas driver, are you running Spring Mt next weekend with speedventures. I have a feeling that you have a lot to learn, if you want to track monthly, keep it stock for now.
Old Sep 30, 2013 | 08:32 AM
stuartc323's Avatar
stuartc323
I will second this statement just for the fact that your asking about what are the right spring rates for your setup. Stick to the stock car and learn that first, than move up to coilovers
Stevo Z
Oct 3, 2015 09:14 PM
