Brake Fluid Capacity?
Old Oct 18, 2013 | 08:38 AM
Zume's Avatar
Zume
Default Brake Fluid Capacity?
I am putting AP Racing brakes back on the car. They were off and the system completely drained.
How much fluid do I now need to re-fill re-do system? Is one liter enough?
Old Oct 18, 2013 | 08:51 AM
shadow191's Avatar
shadow191
Maybe get 2. 1 liter should be enough to refill the system, but you'll lose a decent amount while bleeding them and such. I just swapped Akebono's on the front and installed SS lines front and rear. It took less than a liter to fill the system, but all in after bleeding and such, it was like 1.5+ liters.
Old Oct 18, 2013 | 09:09 AM
Waiz's Avatar
Waiz
You posted this in the wrong section so I moved it
A simple search netted the following:
https://my350z.com/forum/brakes-and-...-capacity.html
Old Oct 18, 2013 | 09:36 AM
Zume's Avatar
Zume
THX
I'm on my ipad mini so errors can happen. + not at home so research a little more difficult. + looking for the easy answer.
Old Oct 18, 2013 | 02:44 PM
terrasmak's Avatar
I can do an install and bleed with a little over 1/2 liter, others may use more fluid in the bleeding process
samansharif
Sep 25, 2015 12:31 PM
