front control/A arm- are they quality products?
Old Mar 4, 2014 | 09:16 AM
KhanMan's Avatar
KhanMan
Default front control/A arm- are they quality products?
So, I noticed that I am having some camber issues, where now my front tires are unevenly wearing out(treading on the inside of each tire wore out faster the outside treading). It looks to be a camber issue, though not really sure how that can be as I am not lowered, with the only suspension mod being replacing my stock worn-out shocks with D-specs. When I was getting my tired replaced the mechanic said my front passenger side a arm needs to be replaced(& adjusted) as it's a tad loose. Okay, that all I said I started to do a search for replacement parts, which as led me to noticing on amazon these products, which says also works for the gen 1 G35 sedan. My question is are they any good/worth it? The price seems certainly pretty good, but not familiar with the products. If not is there any suggestion on what to get as a replacement part that will also fix my camber issue? Thank you.
Dorman 521-606 Control Arm : Amazon.com : Automotive Dorman 521-606 Control Arm : Amazon.com : Automotive
Godspeed Nissan 350z 2003 04 05 06 07 2008 Front Upper Camber a Arm (Will Fit G35 Also) Suspension : Amazon.com : Automotive Godspeed Nissan 350z 2003 04 05 06 07 2008 Front Upper Camber a Arm (Will Fit G35 Also) Suspension : Amazon.com : Automotive
Truhart Adjustable Front Upper Camber Kit 350Z G35 : Amazon.com : Automotive Truhart Adjustable Front Upper Camber Kit 350Z G35 : Amazon.com : Automotive
Old Mar 4, 2014 | 09:18 AM
travlee's Avatar
travlee
Master
look at spc, kinetix, or spl instead. dorman is oem replacement, godspeed is usually crap, and never heard of truhart
Old Mar 4, 2014 | 10:03 AM
KhanMan's Avatar
KhanMan
Well all I am really looking for is a replacement(well a little better would be nice) to fix my camber issue, and worn out part. What about Raybestos, Beck-Arnley, or Megan Racing? I don't want to spend thaat much.
Old Mar 4, 2014 | 10:04 AM
travlee's Avatar
travlee
Master
i have the spc and no complaints, if money is no object get the spl, if on a budget get the kinetix. they are all adjustable as where oem are not.
Old Mar 4, 2014 | 10:25 AM
KhanMan's Avatar
KhanMan
Well do I need adjustable is the question? Because I am pretty much stock, minus the D-Spec shocks and 2006 G35 coupe sway bars, but I am still at stock ride height. I rather save the extra cash and put it towards gas, if adjustable control arm is not necessary. Thank you.
What about Megan Racing kit?
Old Mar 4, 2014 | 10:30 AM
travlee's Avatar
travlee
Master
megan racing is not known for quality parts... adjustable arms are only good if you go to a tuner shop for an alignment, like i said the oem ones are not adjustable so even if you have them no alignment place will touch them
Old Mar 4, 2014 | 10:42 AM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
If you don't have plans to lower the car dramatically then you just need OEM replacement arms.
Old Mar 4, 2014 | 11:10 AM
KhanMan's Avatar
KhanMan
No plans to lower the car. And shop I go to previously aligned my car with stock arms, when installing the d-specs, and replacement oem bushings. I take just replacing the oem will fix my uneven tire wear(camber) issue?
Allstar what brand oem do you suggest I should get?
Old Mar 4, 2014 | 12:38 PM
travlee's Avatar
travlee
Master
check out courtesyparts.com or rockauto.com for oem replacements
Old Mar 4, 2014 | 01:20 PM
KhanMan's Avatar
KhanMan
I did and there are three options available, which is part of the reason I stated this thread. I am not one would be the better oem brand. There is Raybestos, Beck-Arnley and Droman, all of which have been aforementioned. Thank you.
Old Mar 4, 2014 | 01:33 PM
ZROCM's Avatar
ZROCM
I'm now running stock height and I have SPC A arms in the front. They can be adjusted for best alignment where you want it. Simply better than non-adjustable arms.
Old Mar 5, 2014 | 07:17 AM
QTB's Avatar
QTB
Sounds like you just need the OEM replacements. The only adjustment on the front is 'toe'. If you're having wear issues and you have not bent anything from pot holes or hitting something sizable and the bushings are good, it's toe that needs to be adjusted.
The 350Z has a decent amount of camber (I don't recall the spec off the top of my head) for a street car and by adding an aggressive amount of toe you can accelerate wear and make it look like a camber issue especially if you do not drive it hard in the corners.
Old Mar 6, 2014 | 10:03 AM
KhanMan's Avatar
KhanMan
Thank you. I don't think anything is bent and most of my front bushings have been replaced within the last 3 years. Yeah, all I am really looking for is OEM replacement, but again not sure which brand is the right one to get.
Old Mar 6, 2014 | 10:19 AM
Z_on_TE37's's Avatar
Z_on_TE37's
Just buy some used ones from someone parting out a low mileage car.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
