Very loud thumbing from front
Old Sep 24, 2014 | 05:12 PM
J_Nunez33's Avatar
J_Nunez33
Question Very loud thumbing from front
so lately i have been running into this problem that i cant for the life of me figure out . I have tried searching but none of those topics helped me out. Basically my problem is as soon as i start driving i hear a thumping sound its feelable as well, now the faster i go the faster the thump sounds get and the increase on the feeling on the steering wheel (consistent with sounds). Now when i go 50+mph around turns the thumping gets very loud and is very very feelable, at first i thought my front tires got feathered and they did so i went and got a used set and got Firestone's lifetime alignment. Even with my new used tires and corrected alignment i still get that stupid thumping sound and feeling when driving straight and around turns. I have lifted the the car up and looked at the bushings their not to bad little rips on the compression rod and shock bushing but not loose. i have also looked at the panels and are all on tight and yes my lug nuts are tight 85ftlbs,tires at 33psi.
2003 touring model 98,713k i believe all is original suspension ive also looked at the shocks and they don't seem blown (no leakage)
Thanks for looking and helping
Old Sep 24, 2014 | 06:53 PM
cashmoney03's Avatar
cashmoney03
Front hub. Had the exact same symptoms on mine. Replaced them both and silent. Of course now I've got a clicking noise I can hear while shifting now that the hubs are quiet but oh well. Joys of a used car.
Old Sep 24, 2014 | 07:01 PM
J_Nunez33's Avatar
J_Nunez33
Front hub hmm didn't think of that since i didn't have any play on it, are you referring to #3 or #7 in the pic?
Old Sep 24, 2014 | 07:39 PM
AARONHL's Avatar
AARONHL
Ya most likely your wheel bearing is worn out...it is #7 in that picture, very easy to install it comes as one piece you take off and bolt back on. They are like $200 each for OEM, aftermarket even cheaper, if you can do brakes you can change the wheel bearing.
Old Sep 24, 2014 | 07:44 PM
J_Nunez33's Avatar
J_Nunez33
Great thanks guys! looked at a DIY and it looks way to easy , looks like i got something to do saturday . Thanks again!
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
