Quick questions about the OTS Koni Yellows (already searched)
Old Dec 7, 2014 | 09:51 PM
Frostydc4's Avatar
Frostydc4
Question Quick questions about the OTS Koni Yellows (already searched)
Just to confirm do the OTS Koni yellows have height adjustable perches & can the rears be adjusted w/o removal? Also, what increments do they allow you to place the spring (ideally @ .25" would be ideal since I'm looking to keep my car @ stock height or lower @ .25"-.40" at the most)?
Old Dec 9, 2014 | 03:38 AM
guitman32's Avatar
guitman32
Yes there is a threaded collar that is compatible with the front Koni SAs. Since it is a threaded collar on both the front and rear (rear is on the spring bucket) your range of adjustability is infinite withing the max and min settings.
There is also the snap ring that you can set in two places on the front damper which will determine where the threaded collar rests on the damper body.
Old Dec 14, 2014 | 11:24 AM
dizenman's Avatar
dizenman
I just installed these on mine. Right now I have 500lb x 2.5 ID x 8 inch springs upfront. My ride height is currently about 1/4-1/2 an inch higher than stock at the lowest settings. I have a set of 7 inch springs on the way that will hopefully fix that. IF that doesn't work I am going to get aftermarket top mounts as well. For the rear I have 8 inch x400lb 2.5 ID springs that I am using with bc racing upper and lower spring perches. Still dialing it in, but it feels awesome so far
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
D_Rod
Sep 29, 2015 04:42 AM
samansharif
Sep 25, 2015 12:31 PM
