Poly bushing to SPL (compression rod)
Old Feb 23, 2016 | 02:16 AM
RobPhoboS's Avatar
RobPhoboS
Default Poly bushing to SPL (compression rod)
Hey guys,
I'm sure some of you have gone from a polyurethane bushing to the solid SPL type specifically on the compression rod (banana arm), and I wondered if you noticed any difference in steering response ?
I've currently got very high quality adjustable SuperPro one's on my compression rods but wondered if SPL would give even more response ?
Old Feb 24, 2016 | 06:58 PM
guitman32's Avatar
guitman32
Short answer is yes they will perform better.
Are they (and the noise) worth it for you?
Probably only if you are lowered and/or tracking the car with sticky tires. Poly LCA bushings will take you a long way. It is lowering the car that kill poly/rubber LCA bushings prematurely and increases the stress on the rack.
Old Feb 24, 2016 | 07:44 PM
terrasmak's Avatar
My personal favorite for a street car is Whiteline for the LCA and SPL for the compression arm. I really feel the compression arm should be a solid mono all from the factory.
Old Feb 24, 2016 | 11:48 PM
RobPhoboS's Avatar
RobPhoboS
Many thanks for the input guys, hopefully on order today for the SPL.
The NVH isn't an issue, it's not a daily driver but even if it was, I don't mind
Old Feb 26, 2016 | 08:58 AM
rich2342's Avatar
rich2342
If doing the Front Whiteline Lower control Arm Inner bushing, should anything else be needed?
Old Feb 29, 2016 | 03:06 AM
RobPhoboS's Avatar
RobPhoboS
I've bought the SPL compression rod and FLCA inner bushings now.
I should have done that from the start - and all the bloody info is already here as to why on Jasons post heh.
StreetStandard
Body Exterior
119
Jan 26, 2017 11:51 AM
13ringinheat
Suspension
22
Apr 3, 2016 02:16 PM
phelannz
Feb 26, 2016 08:27 AM
aredd2009
Suspension
Jan 30, 2016 07:27 PM
