Program new ABS pump?!
Old Mar 26, 2016 | 07:08 PM
pr_350z's Avatar
pr_350z
Unhappy Program new ABS pump?!
hello there, got a 350z 04 track edition 75k miles, the car turned on the VDC OFF, SLIP, ABS, BRAKE lights. got it to a mechanic, he diagnosed a bad ABS pump after reading the codes,so i bought one with the same part number, but ive been hearing you need to program these pumps after changing them! is that true? if so can a snap-on machine reprogram these, or do i NEED to go to the stealership?
Thanks for any input on this!
Old Mar 27, 2016 | 03:13 AM
karlt's Avatar
karlt
The pump, also called the VDC actuator, is an electro-mechanical unit that isn't programmable. However, the entire system is controlled by a VDC/TCS/ABS control unit, mounted under the dash above the driver's pedal assembly. This unit is accessible through the data link connector, but the service manual doesn't say anything about reprogramming.
Old Mar 27, 2016 | 07:52 AM
pr_350z's Avatar
pr_350z
ohh i see, maybe nissans don't need programing(which would be great), i kept searching and most cases i saw that needed reprogramming where european cars(mercedes, bmw, and so on, although i did saw some nissan Titan owners talking about reprogramming but who knows). Lets see how this goes.
Old May 28, 2016 | 05:20 PM
pr_350z's Avatar
pr_350z
UPDATE, it was a chewed wiring causing the problem, changed pump first anyways and seemed to not need reprogramming.
Old Jun 15, 2016 | 09:12 AM
mberthia's Avatar
mberthia
You mean by an rat or mice or just from rubbing on other parts?
Where exactly was the frayed wiring ?
Old Jun 24, 2016 | 06:07 PM
pr_350z's Avatar
pr_350z
yeah a rat had chewed the wiring right where it starts going into the heat shield in engine bay.
LotusCorps
North Central
Apr 17, 2016 07:29 PM
Stephen_Neri
Mar 23, 2016 09:33 AM
04grayz
Mar 15, 2016 04:19 PM
04grayz
Mar 14, 2016 05:56 PM
