2005 Steering Knuckle replacement help *with pics*
Old Mar 29, 2016 | 09:16 PM
DesertZ's Avatar
DesertZ
Default 2005 Steering Knuckle replacement help *with pics*
Hello I have a 2005 35th Ann Z and recently replaced the steering knuckle. Where the old original knuckle had a plastic seat, it doesn't appear that the new one does. It slides far further and seems to have more play. Do I need to transfer the plastic seat? Is this normal? Thanks for any help!
The replacement part I have is 40015AL55J
The picture on the left installed is the new knuckle. See how high I can screw the bolt down?
The second is the old knuckle with a plastic seat.
Attached Thumbnails 2005 Steering Knuckle replacement help *with pics*-20160329_212043.jpg   2005 Steering Knuckle replacement help *with pics*-20160329_203747.jpg
Old Mar 30, 2016 | 12:09 AM
CJs_Z33's Avatar
CJs_Z33
Only you can verify if the new knuckle has the cone seat for the lower ball joint. But yes, you need that seat for proper installation. Transfer it over if you dont have one on the new knuckle.
Old Mar 30, 2016 | 05:54 AM
DesertZ's Avatar
DesertZ
Thanks cj. I just didn't know if there was a new design? Any idea how to get that cone off? Does it screw off? I tried but it wouldn't budge
Old Mar 30, 2016 | 07:14 AM
RobPhoboS's Avatar
RobPhoboS
I imagine you need a ball joint splitter.
Old Mar 30, 2016 | 07:56 AM
DesertZ's Avatar
DesertZ
I thought about that. Just wondered if it's threaded. Damn wish I knew before I yank it off. I have ball joint splitter. Thanks for input!
Old Mar 30, 2016 | 08:11 PM
DesertZ's Avatar
DesertZ
This worked!
The part is 40173-AL500
http://www.nissanpartsdeal.com/parts...173-al500.html
its a seat that DOES NOT come with the OEM Spindle.
Old Mar 30, 2016 | 09:23 PM
terrasmak's Avatar
Little heat from a propane torch and it falls right off
cashmoney03
May 23, 2016 05:53 PM
ssmokeyy
Mar 28, 2016 05:41 PM
Pete5150
Mar 24, 2016 08:20 PM
