Remanufactured Brembo calipers?
Old Jan 17, 2017 | 04:52 AM
  #41
dcains's Avatar
dcains
Soak them at least overnight with PB Blaster, and use a box wrench, or a socket wrench to remove them.
Old Jan 17, 2017 | 06:26 AM
  #42
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I've been soaking them in wd40, but I just got some fancy $10 a bottle probably the exact same as pb blaster lube ill spray on their... I've been using the small impact in hopes of not breaking the bolts off inside the caliper... So far so good.
Thanks for all the good info btw..
Did you just get yours from napa and not bother with giving back a core? Im still debating just getting remanufactured and painting them.
Old Jan 17, 2017 | 08:09 AM
  #43
dcains's Avatar
dcains
I've had two sets. One I bought used and had powder coated and I rebuilt them using OEM kits, and the others came from NAPA. But the NAPA ones I got were the real Brembo's, so I paid the core, which was $150 each IIRC. I also had them powder coated and resold them. My powder coat guy does a 3-layer finish, with the logo under the final clear coat, so they look amazing.
Old Jan 17, 2017 | 04:17 PM
  #44
dboyzalter's Avatar
dboyzalter
Those did come out super outstanding... I went ahead and saturated the remaining bleeder screws with nano... Never heard of it before but it cost more so it must be better...
I'll keep my fingers crossed, put another round on tomorrow and will see when I get motivated to finish my clean up.
Old Jan 17, 2017 | 04:42 PM
  #45
dcains's Avatar
dcains
You can also try tapping the end of the bleeder with a small hammer, but gently, before loosening.
Old Jan 20, 2017 | 08:53 AM
  #46
PortugueseG35's Avatar
PortugueseG35
How have these Reman's held up? Im looking at probably getting the A1 Cardone Reman Brembos since Centric Remans are harder to find?
Old Jan 23, 2017 | 06:12 AM
  #47
rancor's Avatar
rancor
So far just fine for me. I have only done ~2000 miles on them and one autocross session on them. I am having some issues with noise but that is very likely related to the aggressive pads I have.
Old Jan 23, 2017 | 10:58 AM
  #48
rich2342's Avatar
rich2342
Originally Posted by dboyzalter
I'm talking about these sweet brembos... One of my bleeder screws came out and kept half the aluminum (top) portion of thread with it. Its probably still fine and very usable... But they also came off a car with 210k miles on it so they probably could use a nice rebuild. They have cleaned up pretty nicely though.
I just got new rotors and pads for my base brakes I will keep those, but im still debating what im going to do with these sweet factory brembos.
Just get new seals and rebuild them, perhaps a new powdercoat and you are golden. (see what i did there)
I did it a while back from ebay:
https://my350z.com/forum/brakes-and-...ide-color.html
Old Jan 23, 2017 | 02:48 PM
  #49
dboyzalter's Avatar
dboyzalter
Problem is one of the 8 bleeder screws got a little stripped out
Old Jan 3, 2019 | 07:29 AM
  #50
MaxD350's Avatar
MaxD350
Any reason you couldn't use remanufactured Akebono rear calipers (since they're cheap and available) along with Brembo remanufactured front calipers (since they're cheap and available)? Especially if you plan to paint them as a batch to match. Assuming you don't care that it's not a matching set. The benefit being price, availability, and less fitment issues on the front using Brembo, and not needing new mounting bolts in the rear if upgrading from non-sport.
Old Jan 4, 2019 | 07:40 AM
  #51
rancor's Avatar
rancor
Brake balance would be an issue as the Akebono rotors are larger so you would shift brake bias rearward. Its a safety issue as too much rear bias is dangerous and can cause instability under breaking. Upgraded front and rear brakes should try to match the orginal brake bias of the oem setup for the street.
Rotor size for Brembo vs Akebono (370Z sport brakes)
Rear: Brembo 322mm vs Akebono 350mm
Front: Brembo 324mm vs Akebono 355mm
ssmokeyy
May 5, 2016 09:50 PM
carboyanno
May 5, 2016 07:28 AM
tuko316
North East Marketplace
May 3, 2016 01:22 PM
yosip1115
Apr 15, 2016 11:26 AM
