Rear Wheel Toe Out
Old Dec 15, 2016 | 05:06 AM
Mark Engle's Avatar
Mark Engle
Default Rear Wheel Toe Out
I am working on a 350z that clipped a guardrail. The rear right wheel was toeing out. I replaced the upper control arm and it is much closer but still slightly toed out. I noticed some damage to the sheet metal near the spring perch. I suspect the spring perch my be off and that maybe the spring is bent. Would this cause the toe out? I am thinking of changing to true coilovers in the hopes that I can not worry about the spring perch. Anyone have any experience with this type of thing?
When I got it
After I replaced the upper control arm and fixed the body damage. Don't judge my body work. I only primed it to see how bad the damage was after pulling the quarter out.
Old Dec 15, 2016 | 05:47 AM
travlee's Avatar
travlee
Master
rear subframe may be jacked up
Old Dec 15, 2016 | 05:49 AM
Mark Engle's Avatar
Mark Engle
How could I figure out if it is?
Old Dec 15, 2016 | 05:53 AM
Mark Engle's Avatar
Mark Engle
I did remove the spring and reattached the swing arm the the toe issue seemed to go away. Not sure if that tells me anything or not.
Old Dec 15, 2016 | 08:22 AM
terrasmak's Avatar
Left and right use the same arms. You have an extra set of good arms for measurements
Old Dec 15, 2016 | 10:35 AM
Mark Engle's Avatar
Mark Engle
Dang that is a great idea I should have thought of. Thanks
sry110
North East Marketplace
Jan 18, 2017 05:39 AM
