Street coilovers
Old Sep 29, 2017 | 12:31 AM
Xrabbix's Avatar
Xrabbix
Default Street coilovers
Looking at getting a set of coilovers. I run my car on the street only. Basically weekend car.
I am running rpm1 18x9.5 / 18x10.5 and tire sizes 255/18/40 front 275/18/40 rear if that matters.
I'm not looking for an ultra drop, maybe an inch? Just enough for my wheels/tires to fill in nice.
Iwas looking at the bc true coilovers but I hear mixed things (quality control with the springs being uneven)
Whats a good complete coilovers package (prefer true coilovers) for a dude just looking to run street only with enough drop to make my RPF1s look sexy without an extreme drop.
​​​​​​Basically my cars stock suspension is toast and it's time to replace it all, might as well go coilovers. My budget is $2000
Was looking @ Bilstein pss10 as well.
Also any other bushings I should be replacing while in at it aka preventive maintenance? (Already doing the diff bushing)
Old Sep 29, 2017 | 04:52 AM
jdmfetish's Avatar
jdmfetish
I have stance. Happy so far. Check them out .
Old Sep 29, 2017 | 07:13 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
[/left]
Why?
If you are a street runner and do not need the height adjustment and 28,000 jounce/rebound adjustments for track suitability, why coilovers?
I'd go high end static and use money saved for a set of sway bars.
Y'know, stuff that works to actually improve handling coupled with reasonable ride comfort.
Note: good coilovers will help do that but at the expense of ride and offer only a "small amount" of roll stiffness adjustment needed vis a vis sway bars. Note the word "good", next to "coilovers". The Stance units aren't bad (had them on a different car as purchased) but they were the most horribly stiff riding shocks/springs I've EVER had - even with all pre-load taken out and set to full-soft. Again, it's about how you use the car. My original race car had a better riding suspension with Dat Comp springs and Konis Series D for perspective.
Just IMO.....
Old Sep 29, 2017 | 01:31 PM
terrasmak's Avatar
KW v2 if you want damper adjustment , V1 if not.
Old Sep 29, 2017 | 02:04 PM
ottacat's Avatar
ottacat
Or ST XTA coilovers which are made by KW and are essentially V2's without the inox-line stainless steel. They aren't "true coilovers" as you indicated in your original post but I've yet to see a compelling argument for true coilovers vs. those that use the OEM spring buckets for the rear springs.
These, the KW's and the Bilsteins all use progressive springs which are much friendlier for street use and yet still perform well on the track.
