front ball joint replacement.
Old Dec 13, 2017 | 09:24 AM
trusovici's Avatar
trusovici
Default front ball joint replacement.
Just did mine yesterday using Autozone parts and tools. Model year 2004 Here is a list of tools and some pics.
Autozone Parts/Tools:
Part # DBJ 148 ( ball joint )
Part # 27310 ( master ball joint installer/remover set )
Part # 27023 ( ball joint press )
Part # 27011 ( 3 jaw puller )
And its 41mm in diameter, sorry the battery died.
Steps for removal and re-installation:
1. Remove Cone Washer from old BJ using a 3 jaw puller then remove factory retaining clip.
2. Locate Sleeve # 27310B and #27310N
3. Place receiver 27310B over ball joint making sure the BJ stud is centered with the hole on the top of the press. Then place the smaller remover 27310N into the bottom of the ball joint. The remover has a smaller portion that fits inside the bottom of the ball joint perfectly. Use an impact or alot of elbow grease and a pipe to remove ball joint.
center the stud
4. Locate Sleeve # 27310D and # 27310K. Place 27310D on top of new ball joint with 27310K underneath as the receiver cup. I greased my joint before installing. Once pressed install the retaining clip and your done.
Hope this helps anyone out there looking to do this. it wasnt that hard using a vice outside of the car. air tools help alot. good luck.
Old Dec 14, 2017 | 06:48 AM
iideadeyeii's Avatar
iideadeyeii
IDK why they make it so hard to change these. You shouldn't need 4 tools to change one part that has one bolt on it, but good write up for people who are near a place that can rent these tools for free.
Rather tedious than hard, but you get what I'm saying. Also, I'm aware there is a ratchet or impact wrench, a socket and snap ring pliers which would add to my count of tools :P
Old Dec 15, 2017 | 06:36 AM
ARRRT's Avatar
ARRRT
Thanks for the usefull writeup!
Going to do this next week.
Ordered the balljoints from z1 though...
Old Dec 15, 2017 | 12:32 PM
zakmartin's Avatar
zakmartin
Outstanding write-up! The only thing I'd add is that you need to replace the cone on the factory control arm with a replacement:
Nissan 40173-33P00 Ball Joint Seat Nissan 40173-33P00 Ball Joint Seat
It's Nissan's cute little way of saying, "If you're not going to buy OEM parts, we're going to make you buy OEM parts." You risk damaging or destroying the aftermarket boot on the new ball joint if you don't use one of those.
Old Dec 16, 2017 | 06:49 PM
Nismo Ninja's Avatar
Nismo Ninja
Thanks for the updated info! My joints need replacing as well and wasn't sure what size cup I needed to push the new joint in. I have a shop press so that should make life a little easier.
Also while I'm down there I'll be checking and probably replacing the joint on the compression rod and the traverse link. A good thing to do especially for you guys who are lowered.
Old Dec 18, 2017 | 06:50 AM
trusovici's Avatar
trusovici
the only ball joint that is replaceable is the one contained in the upright. the other joints are cast into the arm's themselves.
Old Dec 18, 2017 | 06:52 AM
trusovici's Avatar
trusovici
i removed and reused the original cone washer. i used a 3 jaw puller as shown in the original post.
Old Dec 18, 2017 | 06:54 AM
trusovici's Avatar
trusovici
yeah, i bought a press to do the job. any excuse to buy new tools right!
Old Dec 18, 2017 | 01:49 PM
Nismo Ninja
My mistake. You are correct, that is the only ball joint that is replaceable. I meant to say the "Bushings" in the Compression Arm and Traverse Link.
Old Dec 18, 2017 | 04:06 PM
zakmartin's Avatar
zakmartin
Makes sense. I haven't disassembled my old rear control arms to replace everything yet. I just swapped out the whole assemblies for a new set of Moogs. I did get new bushings and ball joints for a re-build on the OEM arms though. It's nice to know you can re-use those stupid cone washers. Thanks again!
Old Dec 22, 2017 | 06:35 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I usually use this to remove the cones... Along with the shop press.
This is also a good option for cone removal.
Old Dec 23, 2017 | 04:59 PM
TangoAlphaZulu's Avatar
TangoAlphaZulu
Just an update. Ball joint successfully changed. You post made it very easy to walk in to the parts store and walk out with just the right tools.
Getting tools: easy. Actually getting the ball joint in and out: Not as easy....
Old Dec 24, 2017 | 06:24 AM
dboyzalter's Avatar
dboyzalter
Good write up I'm trying to find the exact sizes needed.. Thanks for adding part numbers and stuff.. Here is a handy chart.
Old Dec 26, 2017 | 07:05 PM
zakmartin's Avatar
zakmartin
I checked the OEM cone washer part and the diameter of the hole is slightly larger than the factory OEM ball joint bolt. It's snug, but doesn't require a puller to remove. I went ahead and pulled the cones off the old ball joints just for giggles. Easy peasy with a puller.
rottingcat
Jun 16, 2016 09:00 AM
bigherm
Suspension
Nov 7, 2012 09:42 AM
Chuck1000rr
Sep 28, 2009 10:58 PM
JonathanG35
May 22, 2005 01:43 PM
