Veering and wobbling over bumps
Old Apr 3, 2019 | 02:09 PM
Devins_z33's Avatar
Devins_z33
Default Veering and wobbling over bumps
Does anyone know what might be the cause of my Z veering to the right over bumps/potholes?
When my passenger side rear wheel drives over a bump or pothole it'll veer over to the right and wobble back into place. It doesn't happen when the left side drives over a bump, instead it stays stable when that happens.
Thanks in advance.
Old Apr 3, 2019 | 02:14 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Could be worn shocks with poor rebound qualities. How many miles are on your current shocks?
Old Apr 3, 2019 | 02:19 PM
Devins_z33's Avatar
Devins_z33
I wouldn't know, I bought the car about a year ago, haven't changed them since I bought it. Is there any way to check the shocks to see if they're the source of the problem?
Edit: Since buying the car, I know I put on 10k on it, but I am not sure about the previous owner
Old Apr 3, 2019 | 04:23 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
What’s overall mileage on car?
Get under and check for the mfgr markings.
If they’re OE shocks and you have more than 50-70k miles, they’re pretty much toast.
But in addition to possible bad shocks, there could be (probable) front suspension wear... control arm bushings, steering linkage, etc All prone to wear and aging. You didn’t mention the year of the car but at minimum, its ten years old and up to 16! Things wear out.
If you’re not able to diagnose, take it to wherever You get it aligned and have them check the front end. (Not guesses but “OK, if you think it’s that and you replace it, that had better be it.”)
Old Apr 3, 2019 | 04:33 PM
Devins_z33's Avatar
Devins_z33
Overall mileage is 120k. But the previous owner installed coilovers and I'm not sure what brand, nor how old they are/how many miles are on them. Its worth noting that I took it to a mechanic recently and he found that the passenger side rear coilover was on backwards, (which was causing a ticking noise).
They've since been reinstalled correctly and the ticking sound was fixed, but still do the wobbling thing described in the OP. I suspect the rear passenger coil may have worn from driving on an improper installation.
Old Apr 4, 2019 | 05:55 AM
Cracka350's Avatar
Cracka350
It's worth mentioning that any lower bushings control arm sway bar dif etc are pretty worn out if they havent been replaced. Mic's right. Check the shocks first. But a bunch of urethane bushings are good for business.
Old Apr 4, 2019 | 12:02 PM
Flee0588's Avatar
Flee0588
A bad toe angle could cause the wheel to grip in a certain direction after hitting a bump.
CrowzRSA
Sep 21, 2015 04:00 PM
charlie_rdstr_Z
350Z Roadster
13
Jun 7, 2007 07:22 AM
charlie_rdstr_Z
Jan 28, 2006 07:52 PM
dchi_t
Oct 28, 2005 10:12 AM
