Front Brembo Caliper, STD brake caliper rear
I bought a set of front Brembo calipers(REMAN) and will install this weekend, For the mean time as I am still searching for a set of Rear Brembo calipers, I will let the rear unchanged(STD brake caliper). In the front setup, Can I used the OEM brake lines instead of stainless steel braided lines as many suggested?
You're not gonna find a set of reman rear brembo calipers, just a heads up. It took me a month to find a set used and it was off of an obscure ad on letgo. Call people on car-part.com and check your local offerup and letgo. Be patient. Wish you luck.
Thanks folks, I found a pair in ebay, its reman and a little bit pricey. Painted it red, put brembo stickers and I've been using since July, installed stainless steel brake lines and I can tell the big difference of the braking power of these brembo calipers and brembo rotors installed on my 350z. To those people saying it's just a bling, they're wrong. I spend $1200 for this upgrade, I saved a lot because, I did the installation myself.
Kingeddie
Brakes
Jul 31, 2013 06:49 PM
