Stripped mounting point for rear subframe stay--Help!
Old May 28, 2019 | 12:10 PM
Glaceo's Avatar
Glaceo
Default Stripped mounting point for rear subframe stay--Help!
So, in the removal of my rear subframe stay on the drivers side,
the two points where the stay mounts back up are stripped.
For reference, its the two holes at the bottom of the second pic that are stripped. I tried old and new hardware in them, but neither will begin to grab the threads. Can I drive without these bolts installed? If not what are my options? I am not sure if I can try to retap those threads or not. Thanks
Old May 28, 2019 | 12:15 PM
coletrickle74's Avatar
coletrickle74
Try cleaning up the threads with a tap first.
Old May 28, 2019 | 12:22 PM
Glaceo's Avatar
Glaceo
I'll go buy a tap then.
Old May 28, 2019 | 12:39 PM
travlee's Avatar
travlee
Master
Make sure you know the size and thread pitch
Old May 28, 2019 | 01:32 PM
260DET's Avatar
260DET
If the thread is long enough and not stripped all the way put a spacer under the nut so it engages good thread.
blue350zed
Suspension
13
Feb 16, 2015 06:39 PM
brother_david
Nov 11, 2014 07:24 AM
Ronp350z
Suspension
Jun 24, 2013 04:57 PM
timsam
Jul 1, 2008 02:23 PM
