Shocks and Struts please help! Bouncing Z
Old Jan 20, 2020 | 12:36 PM
Zena8956's Avatar
Zena8956
Default Shocks and Struts please help! Bouncing Z
My car is bouncing a lot and it’s scraping off tread from my tires. I don’t want to roll my fenders so I was thinking about buying new struts and shocks as they are probaly really worn. I think they are stock and I have 111,000 miles . I want to make my car stiffer but I also cannot afford 1,000 dollar shocks/struts. This has probaly been posted a million times but it’d help a lot. Thanks
Edit: I’m asking if for advice on which shocks/strut to buy
Old Jan 20, 2020 | 12:56 PM
travlee's Avatar
travlee
Master
was there a question I missed in here?
Old Jan 20, 2020 | 12:57 PM
jhc's Avatar
jhc
General & Tech Moderator
A "strut" setup simply means the shock and spring are mounted as 1 assembly (fronts). The rears are conventional. Oems are no longer made. You need shocks. Dunno about cost, I DIYd.
Bilstein B6 is an excellent choice, B8 if lowered.
Old Jan 22, 2020 | 11:34 AM
iideadeyeii's Avatar
iideadeyeii
They are def not stock
Old Jan 23, 2020 | 08:56 AM
Heel Til I Die's Avatar
Heel Til I Die
If the tires are being torn up from hitting the inside of the wheel well, then it's definitely time for a suspension refresh.
if the tires are being shredded from hitting your fenders because they protrude past the body, then you need to roll your fenders or get higher offset wheels. I doubt new suspension is going to stop your tires from hitting your fenders unless you run some obscene amount of negative camber. If you do that, then it's going to prematurely wear the inside of your tires and you're going to have the same issue.
I passed a civic the other day on the highway with wheels/tires that stuck out about 2 inches past the body. The fenders were beat to crap. Stancenation, bro!
Old Jan 26, 2020 | 10:14 PM
terrasmak's Avatar
Tien basics ,you get shocks and struts for a great price
Old Mar 1, 2020 | 09:54 PM
ScaryFatKidGT's Avatar
ScaryFatKidGT
Is you ride height stock?
Tein Endurapro plus or Bilstein B6's
TangoAlphaZulu
Jan 29, 2018 05:56 PM
ZROCM
Suspension
Apr 10, 2014 06:17 PM
shiner
Aug 22, 2009 05:22 PM
03redlinetrack
Mar 31, 2009 05:07 PM
kelechi77
Sep 27, 2006 07:58 PM
