Coilovers
Old Jan 20, 2020 | 05:33 PM
Zena8956's Avatar
Zena8956
Default Coilovers
My Z has some pretty fat and wide tires so it scrapes the fender when it bounces on an uneven road and sometimes shreds off tire. Really bad. They stick out past the fender, I like the look but I don’t like the tear lol. I am wondering if getting coilovers would help it? If I made it a really stiff ride so it won’t bounce and scrape. Thinking of tein street basis. And if I get them does anyone know if I can keep stock height on my car? I don’t want to get any lower to risk scraping.
Old Jan 20, 2020 | 10:04 PM
813_350Z's Avatar
813_350Z
How wide are your tires? Any possibility of just rolling your fenders enough to provide sufficient clearance for rebound?
Old Jan 21, 2020 | 01:25 AM
travlee's Avatar
travlee
Master
Dont create multiple posts for the same thing
Old Jan 21, 2020 | 07:12 AM
Mully's Avatar
Mully
You can pick up some camber arms for the front and have it aligned with a little negative camber, which should help the issue. For the rear there is a little adjustment stock, which can get you to -2.5*. Note that going with more negative camber than stock will lead to faster and uneven tire wear.
While new shocks and coils may help the tires from scraping on small bumps, it'll likely continue to scrape when going up driveways and other bumps meant for trucks.
Old Jan 21, 2020 | 07:20 AM
travlee's Avatar
travlee
Master
most big box alignment places wont touch the front, since they are not adjustable from the factory
Old Jan 21, 2020 | 10:51 PM
terrasmak's Avatar
I had a really stiff setup on my car, like double the rates of the Tien coilovers you mention. The suspension still moves, you still need to properly set everything else.
drabes350
Oct 5, 2017 04:16 PM
superpilot04
Oct 20, 2016 03:39 PM
sw0ng
May 3, 2007 06:58 PM
nkohler
Feb 10, 2007 08:58 AM
InZpire
Feb 2, 2007 11:17 PM
