350z S-tune springs with Bilstein B8 shocks
Old Feb 6, 2020 | 07:31 AM
windydog's Avatar
windydog
Default 350z S-tune springs with Bilstein B8 shocks
Hi Guys,
I was wondering if anyone is in the same boat as myself. I have a worn out S-tune suspension and want to replace the shocks.
I was considering going with Bilstein B8 setup.
I will not track the car, and honestly don't want a super low car. I already have a 993 at RS height and its a pain to drive around.
Could someone chime in and provide feedback or advise.
I did some research and the PSS10 are hit or miss since the rear is not a "true" coilover system.
Thanks!
Old Feb 6, 2020 | 08:11 AM
travlee's Avatar
travlee
Master
is the springs that lower the car, not the shocks
cant ever go wrong with bilstein
Old Apr 20, 2020 | 01:15 PM
PDose's Avatar
PDose
Don’t mean to revive a dead thread, but I am in the same boat as you. I was looking at the bilstein b8s to pair with my s-tune shocks. How’s the ride?
Old Apr 21, 2020 | 05:40 AM
windydog's Avatar
windydog
I am still trying to find more info. I contacted bilstein and they said it will work. Was hoping someone was in our boat.
Many have said the shocks will raise the car. On my 993, the shocks are threaded so I can adjust the ride height.
If it doesn't pan out, we could switch to swift springs, but for 500 more, you could get pss10 coilovers.
Any luck on your end?
Old Apr 21, 2020 | 06:08 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Will repeat what I said yesterday.... this will be a decent set up. Softens the ride (a bit; but you will feel more control) from the dead S-Tune/Tokico shocks. And, the B8, being made for lowered cars will work well with the slightly lower (~ -20mm from OE) S-Tune springs. There's no magic about these springs, they are comparable to many other performance spring sets out there (with ~ 450/500 rates at max deflection). Ride will still not be like a limo, as the springs are still stiff compared to OE; but the damping offered by the Bilsteins will create a much smoother (controlled) transition between jounce and rebound, the hallmark of Bilstein shocks. Only way to actually give a "smoother ride" is to swap the springs out. Shocks can only control as much as the springs allow them to. Super stiff springs paired with shocks unable to control them results in one thing: prematurely dead shocks. Get the best.
S'far as "raising the car"; yes, possible. Bilsteins tend to do that but it's more like "not allowing the spring to sag" versus actually raising it up. In any case, MAYBE 3-4mm maximum. Personal experience on Z (and similar height deltas on old school BMWs): with Bilstein/Eibach Prokit = -15mm from stock, with Koni/Eibach Prokit = -19mm from stock.
Old Apr 21, 2020 | 06:52 AM
PDose's Avatar
PDose
I haven't gotten them in yet, I just ordered the shocks this morning.
Old Apr 21, 2020 | 06:58 AM
PDose's Avatar
PDose
I do appreciate you replying to both threads, I understand what you were saying. I have read that bilsteins tend to "raise the car up" as you mentioned, and i thought about using the eibach pro kit as well. But there is very conflicting information out there on the how much it lowers our cars haha. I just saw this thread in the related topics, and figured it wouldn't hurt to get some first hand experience on the specific setup. To see if there were any quirks in the way it handled.
Old Apr 21, 2020 | 07:03 AM
MicVelo's Avatar
No worries.
S'far as the Bilstein B12 Prokit, my personal experience with actual lowering is cited in post above.
Old Apr 27, 2020 | 04:53 PM
windydog's Avatar
windydog
Would you mind posting pictures when you have them installed.
Thank you!
WD
Old May 3, 2020 | 04:51 PM
windydog's Avatar
windydog
Ordered B8 today. Going to update rear diff bushing and install suspension next week. Will also change transmission and rear difficulty fluid too.
Old May 17, 2020 | 04:30 PM
windydog's Avatar
windydog
installed them, I can put two fingers between the wheel and fender. I vaguely remember when new, i could put 4 fingers.
Old May 21, 2020 | 09:38 AM
PDose's Avatar
PDose
Nice, I got mine installed as well. I didn't get a chance to measure it before I got them taken off, but it definitely raised my car a bit. I like the ride, I haven't truly gotten a chance to test it out too much, I nearly cut my finger off around the same time. Between that and the lock down I have had to avoid driving a stick as much as possible. How do you like it?
Old May 24, 2020 | 01:06 PM
windydog's Avatar
windydog
I took measurements. All around, the car raised .75", this is based on the dead shock measurements.
The overall drop is .55 inches, I will remeasure in 500 miles.
Hard to say overall, but its nice to have travel in the suspension.
The rear diff bushing was god sent,, no more notchey shifting..
WD
Old May 27, 2020 | 03:46 PM
PDose's Avatar
PDose
Nice, thanks for measuring. That confirms that it definitely raised it, like I thought it did. Although like you my shocks were pretty shot. I need to get out and drive it more to fully test it!
what rear diff bushing did you end up installing?
Old May 28, 2020 | 08:58 AM
windydog's Avatar
windydog
I got the whiteline rear bushing.
I am also going to replace the clutch spring to the softer one.
Overall car drives much better, but need to drive it more as I got to burn out this old fuel.
Old May 30, 2020 | 09:25 AM
PDose's Avatar
PDose
Very nice, the white line bushing is very popular on our car.
I’m the exact opposite I like a stiffer clutch haha
Old May 30, 2020 | 10:02 AM
windydog's Avatar
windydog
The spring is to make the clutch more linear rather than old people like (like me).
I ended up removing the helper spring, which for a 2004 requires you to remove the clutch assy.
I took the car for a spin this morning, and removing the helper spring is amazing. The clutch engages high, but over all very happy for a 0$ mod. The clutch is heavier, so you may like your car even more.
The sad thing, is for the past 10 years I have neglected the car, and was modifying my 911. I just remembered why I love this car again!
Next up will be complete fluid change along with removing the oil filter cooler. There is tons of information about this, and I highly recommend you do the same.
WD
HTX_350z
Jul 15, 2014 09:28 AM
Forever Z
Feb 7, 2011 04:49 PM
jreiter
Jan 13, 2005 09:49 AM
2quick2fast
Nov 2, 2004 06:34 PM
